03 PSD torqueshift fluid mixed
Old Nov 17, 2012 | 12:10 PM
Chauncey237's Avatar
Chauncey237
Friend used my truck and the tranny lines started leaking. He added about 2 qts of Mercon V. The truck was driven about 100 miles. I replaced the complete tranny lines from the tranny to the rad and the tranny cooler. Including a new complete filter housing. Everything is new. I have not refilled the tranny yet. I have to drop what is in the pan. I ordered Mercon 20 Qts SP from Ford. Can someone give me some advise on the next move. Can I take the filter housing off and pump some out with the torque converter. How screwed to you think the tranny is. Thanx in advance.
Old Nov 17, 2012 | 04:01 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It's probably not screwed.
Drain what's in the pan, put it back together, and fill it. It will probably take 8-10 quarts. That's all you will be able to get out without a hot flush machine or taking the trans out and removing the torque converter. Drive several thousand miles and change what's in the pan again.
Old Nov 17, 2012 | 05:42 PM
Chauncey237
Thanks Mark
Thank you Mark. I will do that. Tomorrow and then I will take it to have a hot flush. I see that you are a transmission engineer. The truck only has 33K on it. But its rotting away thanks to the Chinese steel. I only drive it about 3 to 4 k a year. Done the brake lines, oil pan, now the tranny lines. The diff covers are in bad shape that looks like a spring project. Thanks again.
cornell5
Oil & Lubrication
Feb 5, 2015 11:44 AM
pawpaw
1983 - 2012 Ranger & B-Series
17
Apr 26, 2014 08:52 PM
Desert 4x4
Aug 13, 2009 08:16 PM
Z0RR0
Apr 21, 2007 03:19 PM
MJW
Nov 2, 2003 02:18 PM
