Haven't seen this before, front disc brake adapter
well here's the response , hopefully they throw a word doc together .
Michael,
We will be writing the information sheet this week and get this out to you. Our ad was placed while we were plating the new product.
Cheers,
Scarebird Classic Brakes LLC
PO Box 2522
Lynnwood, WA 98036
www.scarebird.com
Michael,
Cheers,
PO Box 2522
Lynnwood, WA 98036
www.scarebird.com
hey guys,
The anodized caliper adapters arrived and reading quickly through the instructions it seems straight forward with the following notes:
Here is the parts list for your info:
Rotors, 76-93 F150 4x4 (front) - NAPA 4885611, Wagner BD60441, Raybestos 6048R
Caliper, LH - 90-02 Astro Van AWD- NAPA SE4850, Wagner TQM25002, Raybestos RC4418
Caliper, RH - 90-02 Astro Van AWD- NAPA SE4851, Wagner TQM25003, Raybestos RC4417
Brake Hose, LH (front) - 82-83 Pontiac Firebird- NAPA UP38102, Wagner F106368, Raybestos BH38102
Brake Hose, RH (front) - 82-83 Pontiac Firebird- NAPA UP38103, Wagner F106369, Raybestos BH38103
Banjo Bolts (Front, Qty 2 included), 82-83 Pontiac Firebird - NAPA 82703, Dorman PN 13940
Two cotter pins, two hose clips (included). You will need a prop valve.
FYI... use the PNs above for crossover applications. For example, the calipers can be sourced from 95-97 half- and one-ton GM trucks and SUVs.
- Take the hubs to a machinist and have the hub flange turned down to fit inside the rotor with 0.010 clearance. This centers the rotor to the hub.
- Lug studs need to be pressed out and replaced with studs 0.25" longer than stock.
- The rotor must sit flush to the hub face. The back of the lug holes may need to be countersunk.
