fuel pressure sensor?
About 10 days ago I got a Check Engine Light. I had the Advance Auto guy connect to the computer and it translated as Fuel Temperature Sensor. I've got a 5.4L Gas engine. On-line I read that it would be the same code for the fuel pressure sensor located on the fuel rail on top of the engine.
I swapped that out and I still have the engine light. What should I do next?
Thanks.
Thanks.
Reset the PCM. Lights don't always go out by themselves immediately even when the underlying cause is repaired. You have to reset it...
Identify your vehicle so we know what you have....
Post the EXACT fault code, not a description or interpretation of the code by some parts store guy....
