Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Brake Guides
- Warning Lights
Important information to help you understand your Ford truck
97 f150 dash warning lights stay on
That last post about the starter engaging by it'self indicates you have harness damage on the cable that goes to the igniton switch.
So it makes no difference when the wires go shorted to one another, it's the same as the ignition switch contacts closing.
The dash lamps are powered through the ignition switch as well as the start circuit.
At the present, there seem no shorts to ground or fuses would blow but there is shorts between leads.
Disconnect the battery until you find it or risk fire.
Good luck.
Good luck.
The following users liked this post:
I replaced the gem yesterday. No random trying to start, or any other of my nuiances. So the starter must also run thre the gem. I just threw the oem solenoid back on. So I only replaced the gem. It showed water on it when pulled. The day before all this began I took it through a car wash. Usuaully I wash it myself.
So where is this leak most common? I can see water on the inside bottom edge of the window. When the trim is reoved on the drivers side.
J.WebsterDesigns
03-07-2019 12:15 AM
JordynM
03-18-2018 01:28 PM
Gage Reagan
1997 - 2003 F150
01-25-2017 01:17 PM
Pwnm30rdi3
15
02-23-2011 07:59 AM
mikef56
07-12-2004 11:47 PM
