Should you run a coolant bypass filter?
#32
They dont even foundry the metal there, its shipped in with tanker trucks and poured.
#33
#35
https://www.ford-trucks.com/forums/1...l#post11351805
Here is my write I made when I did mine. This thread reminds me. I need to change it.
#36
Does it matter in which hose you place the ts? I would reckon that one is supply and return, but is there a good way to identify which is which?
I'm curious as to if I could just find the return from the system and then run that straight into a hose barb in my base, exit the other side of the base with another barb and go right back into the return? It would simply the mess of fittings greatly.
#37
You want your incoming on the incoming line to the heater core and your outgoing line on the outgoing line of the heater core.
They are not full flow, hence bypass, so if you hook them up backwards, it wont work right.
#39
#41
Tayln, do you know of any disadvantages to doing it the way guzzles site has it in this link?
Welcome to guzzle's Coolant Bypass Filter Mod Web Page
#42
#43
I guess I just can't wrap my head around why the t's are necessary. If you run one line into your base and the same line out the other side whatever flows through that line is gonna be filtered, before it continues on to the WP and radiator. Am I missing something big here?
#44
Thus only a percentage of the fluid flows though the filter per cycle.
So lets say 80% of the fluid will go to the heater core and 20% will go though the filter per cycle.
Bypass filters can filter finer materials because they are not flow dependant. A full flow must be able to flow X gallons per minute otherwise will cause a restriction.
