Points Replacement Help
Old Nov 8, 2012 | 09:02 AM
NS70250's Avatar
NS70250
I just installed a Crane Cams XR700 into the 360 of my 1970 F250. It ran perfect before the installation, but not now. It will idle very smooth, but any gas results in backfire and the engine dying. When I take off the vacuum advance it runs pretty good except for when I'm giving it just a little gas it stutters. Does anyone have any suggestions?
Old Nov 8, 2012 | 09:17 AM
MIKES 68 F100's Avatar
MIKES 68 F100
what is your timing set at ? when you installed the cam did you replace the timing chain and gears and line up everything ? more info please
Old Nov 8, 2012 | 12:36 PM
NS70250's Avatar
NS70250
I'm not sure what the timing is set at, I'm going to check it tonight, but I didn't put in a new cam, I installed an electronic ignition/optical sensor.
Old Nov 8, 2012 | 01:56 PM
MIKES 68 F100
just assumed the xr700 was a cam,
Nathan Vos
Apr 29, 2017 02:20 PM
fly-tying.guy
18
Dec 23, 2013 11:43 AM
Jam21
Jan 31, 2012 05:26 PM
NORMAFAN
Feb 21, 2007 01:01 AM
jwrboss302
Apr 10, 2004 01:38 PM
