Rapid-Heat Supplemental Heater
Old 11-06-2012, 06:37 AM
JLMELTO
JLMELTO is offline
JLMELTO is starting off with a positive reputation.
Just purchased my First 2012 F250 Crew Diesel and it came with just about everything you could ask for to include a Rapid-Heat Supplemental Heater. So I've had it about a week and every morning I let the car run (remote start) for about 10 min before getting in. I make sure I set the heat to 80, make sure the system is set to auto before turning off the truck the day before, but every time I get in the car, its still freezing cold inside (this morning the temp was 26 degrees out). I have read many postings about the supplemental heater, but I have no idea how this is suppose to work. The truck will heat up nicely once I'm about 10 min down the road, and even quicker if I'm driving and take it off AUTO and control everything myself. So if possible can you guys give me some feedback on the questions below. Maybe come up with a few tests that I can perform or let me know how your system works?
1. Does the supplemental heater utilize the air vents in the car, or is it a separate system that heats the car?
2. Can someone tell me where the heater is located so that I can verify that it is actually installed.
3. Is there anyway other than taking it to a dealership to verify that it is working properly.
4. Also is it normal than heat doesn't come out of the rear center console vents while driving?
Old 11-06-2012, 06:46 AM
Chief901's Avatar
Chief901
Chief901 is offline
Chief901 is gaining momentum as a positive member of FTE.
The Rapid Heat Sup-Heater is electric elements in the duct system. I have it and it works well, but I never remote start my truck, althought it has remote start. When the dealer was going over things with me, I did notice many electronics did not activate until the key was inserted and turned on after remote start.
Someone else may come along with more experience, I just love the truck.......
Old 11-06-2012, 07:03 AM
kper05's Avatar
kper05
kper05 is offline
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
You say it's in auto so that should be working.
I don't have it but my understanding is it helps heat the cab more quickly once EGT's begin to heat up the engine.
I don't know that it is designed to make the cab hot from a cold start and idle.
For the back vents, I'm fairly certain heat flows from the ducts under each front seat instead of the console vents.
Until someone who does have it comments, here are some details for this system for now.
Originally Posted by PowerStrokeHD View Post
Remote start and EMTC (Electronic Manual Temperature Control)...
When the remote start feature is used, the climate control system automatically sets certain parameters in an attempt to achieve a comfortable cabin temperature. These parameters are set based on outside air temperature. During remote start, the outside air temperature is continually evaluated and HVAC system behavior can change if the outside air changes between cold, moderate and warm temperatures.
For cold ambient air temperatures (below 0C (32F)):
-the airflow mode is set to FLOOR/DEFROST.
-the temperature is set to full HOT.
-the blower speed is set to HIGH.
-the air inlet mode is set to fresh air.
-the auxiliary electric heater is enabled if needed (diesel engines only) (if equipped).
For moderate ambient air temperatures (between 0C (32F) and 27C (80F)):
-the airflow mode is set to the last user setting.
-the temperature is set to the last user setting.
-the blower speed is set to the last user setting.
-the air inlet mode is set to the last user setting.
For warm ambient air temperatures (above 27C (80F)):
-the airflow mode is set to MAX A/C.
-the temperature is set to full COOL.
-the air inlet mode is set to RECIRC.
-the auxiliary electric heater is not enabled (diesel engines only) (if equipped).
The following applies to vehicles with either EMTC (Electronic Manual Temperature Control) or DATC (Dual Automatic Temperature Control).
Climate Controlled Seats (If Equipped) - When the vehicle is started using the remote start feature, the driver/passenger climate controlled seat activates in full heat mode when the outside temperature is less than 0 C (32 F) and full cool mode when outside temperature is greater than 27 C (80 F).
Heated Mirrors (If Equipped) - When the vehicle is started using the remote start feature and the outside temperature is less than 0 C (32 F), the heated mirrors will be activated.
Rear Window Defrost (If Equipped) - When the vehicle is started using the remote start feature and the outside temperature is less than 0 C (32 F), the rear window defrost will be activated.
If I remember right it does not need to be in auto mode and it will adjust the settings as needed upon remote starting...
Remote start and DATC (Dual Automatic Climate Control)...
For cold ambient air temperatures as determined by the HVAC module AUTO mode to request heat:
-the temperature is set to 22C (72F).
-the blower speed is set to AUTO.
-the air inlet mode is set to AUTO.
For moderate ambient air temperatures as determined by the HVAC module AUTO mode to request heat or cooling:
-the airflow mode is set to the AUTO.
-the temperature is set to the last user setting (Temperature setting is limited to 18C (65F) minimum and 29C (85F) maximum. If the temperature is set above or below that range, it will use the minimum or maximum value.).
-the blower speed is set to the AUTO.
For warm ambient air temperatures as determined by the HVAC module AUTO mode to request cooling:
-the airflow mode is set to AUTO.
Old 11-06-2012, 08:26 AM
my_crib_too's Avatar
my_crib_too
my_crib_too is online now
my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.my_crib_too has a spectacular reputation.
Welcome to FTE!!! Congratulations on the new truck.
Old 11-06-2012, 01:22 PM
Painted Horse's Avatar
Painted Horse
Painted Horse is offline
Painted Horse has a spectacular reputation.Painted Horse has a spectacular reputation.Painted Horse has a spectacular reputation.Painted Horse has a spectacular reputation.Painted Horse has a spectacular reputation.Painted Horse has a spectacular reputation.Painted Horse has a spectacular reputation.Painted Horse has a spectacular reputation.Painted Horse has a spectacular reputation.Painted Horse has a spectacular reputation.Painted Horse has a spectacular reputation.
The Rapid Heat supplemental heater is a electronic heater element installed in your ductwork as mentioned above. You can't see it unless you take your dash apart. But if it is on your sticker listing all your options, You got it.
There is no operator controls to turn it on or off. It is totally automatic. When the tempeture is below a certain point and the engine coolant is below a certain temp, Then the suplimental heater elements kicks on. It is only a 1500 Watt heating element. Think of it as a Hair Dryer. So it's not going to totally warm up a Crew cab that has overnight cold soak, where every piece of plastic is 20. But it will help get your windshield defrosted faster. During the winter months, when I remote start the truck, I can come outside after 10 minutes and find all the frost on my windshield has pretty much been melted.
I don't know what Temps you are seeing in VA this fall. But it may not be getting below the trigger point to even turn it on.
Old 11-07-2012, 06:39 PM
Schlava
Schlava is offline
Schlava is gaining momentum as a positive member of FTE.
Painted.....actually I don't think it's auto. On my xlt with manual heat the manual tells me to turn the heat to full hot. That acutates the supplemental heater. Then I turn back the heat to the 3 oclock position and you can hear a difference in the heater and it's truck heat at that point.
Old 11-07-2012, 08:03 PM
Painted Horse
It appears from the details below, that it's automatic on the dual climate automatice systems, but you need to turn you controls above the 80% level on the manual systems to activate it.
An electric heater is available as optional equipment on diesel vehicles. The electronic heater assembly contains the Auxiliary Heater Control Module (AHCM) and element, and is located in the HVAC immediately downstream of the heater core.
Power is supplied to the AHCM element through a fused cable connected directly to the positive battery terminal with an in-line connection at the dash panel heater tube opening. Ground is supplied to the electric heater element through a ground cable connected directly to the negative battery terminal with an in-line connection at the dash panel heater tube opening. The AHCM is activated by a Medium Speed Controller Area Network (MS-CAN) message from the HVAC module EMTC or HVAC module DATC . The MS-CAN message is converted to a HS-CAN message by the Instrument Cluster (IC) module and is then detected by the AHCM .
The electric heater will be activated if all of the following conditions are met:
The ignition switch is in the RUN/START position
The engine is operating at greater than 500 rpm
Any ON mode is selected on the HVAC module EMTC or HVAC module DATC
The temperature set point is greater than 80% of the highest setting ( EMTC only, DATC uses software algorithm based on interior temp and set point)
The engine coolant temperature is less than 85C (185F)
No alternator faults have been recorded and alternator is not at full capacity
The AHCM will be deactivated if any of the following conditions are met:
The ignition switch is in the OFF or ACC position
The engine coolant temperature is greater than 85C (185F)
An alternator fault has been detected or the alternator is fully loaded due to external electrical loads
The engine is operating at less than 500 rpm
The auxiliary heat request is NO from the HVAC module EMTC or HVAC module DATC
Old 11-08-2012, 08:24 AM
rickatic
rickatic is offline
rickatic has a great reputation on FTE.rickatic has a great reputation on FTE.rickatic has a great reputation on FTE.rickatic has a great reputation on FTE.
If the ambient temperature outside is above freezing, 32F or 0C, the Rapid Heat is inoperable. If cold enough, it works as described above. It thaws the windshield and knocks the chill down a bit...it truly is just a 1500 watt hair dryer installed in the heater plenum...
Regards
Old 11-08-2012, 03:05 PM
Jefff H
Jefff H is offline
Jefff H is starting off with a positive reputation.
I know on my Lariat it's been working every morning with 40-60 F degree temps outside. I can feel heat within literally one minute. Sure is nice.
Old 11-14-2012, 02:04 AM
doczenith1's Avatar
doczenith1
doczenith1 is offline
doczenith1 is starting off with a positive reputation.
I did some testing shortly after I got my truck to see how fast I got heat with the supplemental heater and posted the results in the spreadsheet in the link in my sig. You could do a similar test to see if you get the same results that would verify that you have the supplemental heater.
Based on how the system is supposed to work during remote start I would suspect you could check the air temp of the vents after x minutes of remote start to see if the system is blowing heat similar to what my truck was.
Old 03-23-2016, 03:25 PM
rdlouks's Avatar
rdlouks
rdlouks is offline
rdlouks has a good reputation on FTE.rdlouks has a good reputation on FTE.
While far from scientific, my 2016 F-350 is blowing warm air within 2 minutes of driving. In fact I don't know why they don't offer it on all their vehicles gas or diesel.
Old 03-24-2016, 07:07 AM
69cj's Avatar
69cj
69cj is offline
69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.
Regards
Mine comes on when in the 40's.
Old 03-24-2016, 06:28 PM
Karl4Cat's Avatar
Karl4Cat
Karl4Cat is offline
Karl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputation
You guys did some digging to resurrect this one from 2012....
Old 03-24-2016, 06:42 PM
Dakster's Avatar
Dakster
Dakster is offline
Dakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputationDakster has a superb reputation
You lucky person... Mine doesn't seem to work until it's in the low 20s in the morning. It's odd that if it is 30F out that it takes SOOOOO much longer for the heater to blow out warm air than if it is 20f out.
And yes, good work picking up a thread from the past.
Why it isn't in a gasser - My gas vehicles still start to blow HOT air quicker than my diesel truck... So unless you were in extreme cold often enough - like Fairbanks -60F cold, it probably wouldn't make a lot of monetary sense for the manufacturer or the purchaser.
Old 03-25-2016, 10:23 AM
troverman's Avatar
troverman
troverman is offline
troverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud of
I don't believe the outside temp has any effect on whether the supplemental heater operates or not...it only checks to see if the coolant temp is below a certain point, and whether near maximum heat is being called for. On the manual systems (which are actually all electric underneath), functionality is simple - cold start any truck, even on a summer night where it got down to 70F, and turn the heater **** all the way up...the supplemental heater will turn on. On a truck with full auto climate controls, the computer interferes a bit because now the system knows the cabin air temperature. If the interior of your truck is 70F and you set the heat to HI, some unexplained algorithm is used to determine if the heater comes on or not. In either auto or manual climate, however, you will hear a relay click when the heater turns on.
The electric supplemental heater basically looks like a mini heater core, and it is downstream of the actual heater core in the HVAC unit in the dash. This magnifies it's usefulness, because its much easier to heat warmer air. So if the coolant temp flowing through the core is 50F, that is definitely warming the air a tiny bit prior to the electric elements heating it a bit more.
Low blower settings work best; fast fan speed quickly overwhelms.
The reason it is even there is because the diesel engine takes much longer than the gas engine to warm up and provide significant heat. Remote starting your diesel and trying to defrost ice from the windshield would probably be futile without the heater.
Quick Reply: Rapid-Heat Supplemental Heater
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
