Carburetor Help, please :)
It is a lot easier to change the metering rod than it is to change the jet. I have found metering rods for the yfa on ebay.
The YFA uses a rod that has a loop for connection on the one end. Don't confuse the yfa rods with the AFB rods that are L shaped.
Get yourself a carburetor kit, it has a real good diagram of all the parts and you'll need on anyway if you take the carb apart.
Also,,,,,,there are some great videos of the YFA and rebuilding it on youtube.
Also Advance has them. Versions of the YF have been around for years. I wouldn't be surprised if they find one attached to a Dinosaur skeleton while digging around for old bones. There's lots of parts out there.
I need help. I checked voltage at the three wire plug(map), not the center wire but the outer two wires, and found 5 volts dc. Where should I go from here?
Note: will not idle and black smoke from exhaust.
logmode
I have no idea how code readers may present this to users, I just count blinkenlights.
I uploaded some of the MAP/BPSensor stuff from the 1986 Ford Engine/Emissions Diagnostics Manual onto a photobucket album, you should check it out:
For logmode Photos by ctubutis | Photobucket
You will have to read from the last image to the first, that's the way they got organized on photobucket.
I noticed it was sending you to C1 at some point, I just put that stuff up for another guy here... You are interested in C0 thru C6 (again, right to left) here:
For Hutch Photos by ctubutis | Photobucket
I did not do the KOER due to that the KOEO had a code, also it will not idle, and I am not sure how to do it. I need more information on KOER. But since you asked about it, I tried. I started and cracked the gas a little. So I will tell you exactly what I saw. First 3 blinks, 25 seconds pause, 1 blink 4 second pause, fast code (flickers) 4 seconds 1 blink, from here on the pauses are the same 2 seconds- 2-1-3-2-2-4-2-5-8-7-2-7-3-1-2-1-2 -2-2-4-2-5-8-7-2-7-3 stop. That a lot, are they in twos or threes? I tried many more times while I was choking on the fumes, but the code changed. Hmmm?
Can you get me the ECC with inputs sensors and outputs loads or something like that in an electrical schematic?
Do I have to buy a break out box?
Thank you for your help.
You will have 2-digit codes and they'll begin after the flickering; the stuff before then is the engine number of cylinders identification, it may be prompting you to floor the accelerator and/or turn the steering wheel half a turn and/or step on the brake pedal; the flickering is a high-speed output to a code reader; the subsequent blinking is what you're interested in.
It's gonna gibe you 2-digit codes, and it's going to repeat them once.
So, say you have a condition that generates 3 codes - 32, 54 and 34. It'll give you:
32 54 24 three blinks, short pause, two blinks; longer pause; five blinks, short pause, four blinks; longer pause.... two blinks, short pause, four blinks
separator pause (longer than the between-digits pause)
32 54 24 again
These are good sites to read about how to do this:
Fuel Injection Technical Library » How To Run a Self-Test
Ford Ranger/Bronco II EEC-IV Testing
The order in which they appear is also important, keep track.
The engine also needs to be warmed up to do this correctly.
pin1 and pin3 here:
</O
Before I did test I replace the MAP and HEGO. <O
</O
Motor is warm,<O
</O
These are the code that I read during the KOER<O
</O
22 MAP/BP sensor out of self test range.<O
</O
42 No HEGO switching detected always rich (right side).<O
</O
Next one down (58) does not have an X under KOER on the code list, but it came from the KOER test. Why would it do this<O
</O
58 VAT indicated -40�F / circuit open.<O
</O
72 Insufficient MAF/MAP change during Dynamic Response Test (user error).<O
</O
<O
</O
73 TPS senor did not exceed 25% rotation during Dynamic Response Test (user error).<O
</O
If this was you were would you start and do what?<O
</O
The 72 & 73 mean you didn't step on the brake and turn the steering wheel half a turn and then floor the gas pedal when prompted. This prompting will be a flash, shortly after the flash in which it identifies the number of cylinders in the engine but before the hi-speed flickering where it thinks it's sending codes to a code reader.
There is definitely something up with your MAP sensor, I'll see what the book has for pinpoint tests. Do you have a multimeter (volt/ohm meter)? If not, go purchase one, you will need it.
