ECT/EOT deltas way high
Old Nov 2, 2012 | 05:08 PM
BRay09's Avatar
BRay09
My 06 f250 has been running down the highway at 75 for 45 mins. I checked the deltas and ECT is at 190 ( new thermostat) and EOT is at 252. Now the other day after a cold soak of two days at 45 degrees, the EOT was at 90 before starting. The air intake temperature is at 187. Is that right? It's only 36 degrees out. Right now, EOT voltage is at 0.57v. Anything else I should look at?
Old Nov 2, 2012 | 05:30 PM
69cj's Avatar
69cj
How are you taking those readings? You have problems with your readings to start with. Get them straightened out then go after your deltas.
Old Nov 2, 2012 | 05:33 PM
gwg42's Avatar
gwg42
I have similiar issues although the deltas are not as large. There is thread under my user name that you can see responses to my delta issues. Are you using a ScangaugeII?
Old Nov 2, 2012 | 05:51 PM
BRay09's Avatar
BRay09
I am using a Mac tools mentor scanner under the datastream. What am I doing wrong?
Old Nov 2, 2012 | 05:53 PM
Misky6.0's Avatar
Misky6.0
I think the eot is in c* vs f* for ect.
The iphone threads show a formula
Since it is user programable.
The sg2 works properly.
Old Nov 2, 2012 | 05:55 PM
grantpage's Avatar
grantpage
The EOT sensor could be bad, The 2 sensors are the same, so you can swap the 2 sensors and see what the readings are.
Old Nov 2, 2012 | 06:07 PM
BRay09's Avatar
BRay09
I will have to look at that.
BRay09's Avatar
BRay09
Where exactly is the oil temp sensor?
Old Nov 2, 2012 | 06:12 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Bottom pic
Old Nov 2, 2012 | 06:19 PM
BRay09's Avatar
BRay09
Nice, easy to get to. Thank you rusty
Old Nov 2, 2012 | 06:26 PM
Misky6.0's Avatar
Misky6.0
I think eot that high would trigger the fan to go on super high...
Old Nov 2, 2012 | 06:39 PM
BRay09's Avatar
BRay09
I don't ever really hear the fan come on though. Can you hear it in the truck when it comes on?
cheezit's Avatar
cheezit
check aginst iat2. do not use iat1 as it has a maf heater
Old Nov 2, 2012 | 06:57 PM
BRay09's Avatar
BRay09
Will do. Just checked temps again and both read in degF
Old Nov 2, 2012 | 07:59 PM
Rusty Axlerod
Yes Sir! And you will definitely hear it kick up on high (even with the radio on). When I first got my truck and it kicked up towing on hills, first couple of times it happened I was checking my mirrors because I thought someone was trying to pass!
