Well, thanks to the people on this site, I have been Helped many times. After the Slight demise of my motor, and the purchase of another used motor, by next week I will have 8 used injectors, and a Hi preasure oil pump sitting in my garage, waiting to help anyone here on this forum. Now, when I say help, it may be help with a core being sent to Termonator Engineering, or, injectors being sent out so as you can keep driving unitl you get new ones, Or, I will even mail you one or two for troubleshooting purposes ( as was done for me, thank you Al )The deal with this, Once you take posseion of my Cores, You Will be the next "go to guy" .
i to would be interested in the injector swap if they are the right kind. i believe mine are the AB's. early 99. three of mine have clogged nozzels and are not firing, so if yours are working and your just gonna use them for cores.
i dont have any extra parts lying around to offer to anyone else but, my shop,tools and AE are always avalible to anyone needing in the cincinnati area
oh yeah! i have a fpr cap and air intake heater in the brotherhood box also. stock up pipes and baby's butt... and if anyone is insane enough to put it back on a truck i have the stock ccv adapter piece between the 2 intake tubes.
Hi Chris
Old touchofgrey is restoreing another of those fine 7.3s. Ahd would appreciate any parts you have laying around. At the moment I have a long block minus everything else.
Thanks for your help......oh by the way......the Transgo Kit was in the other transmission.
Early 99 Stock turbo pedestal here that leaks out the EBPV actuator hole but can be modified to not leak if anyone is interested. It has the original EBPV solenoid installed in it. I also have a stock air filter and a K&N air filter that fits in the stock air box.
When I do my upgrade to 38R and bellowed up pipes I plan on selling my stock turbo, blank pedestal, up pipes and collector I hope.
