AOD Adjustment
AOD Adjustment
AODs don't use a pressure port - it uses a bellcrank concentric with the shift lever. Early ones may have had a TV rod, but every one I've seen has a TV cable, and it MUST have it installed and adjusted correctly, or the transmission will be SEVERELY damaged by driving. You can see the adjusting clip in the Technical Drawings album in my sig link.
