First fluid changes... thanks y'all!
So did my first ever oil change and fuel filter change this morning on one of these trucks... thanks to you guys and all I've learned here, it went well!
One question, though... are there any tricks to getting the horizontal fuel filter out without getting soaked with diesel? I drained the WIF plug first hoping that would pull most of the fuel out of the HFCM, but there was still TONS that came with that filter.
No clue last time the filters and oil were changed on this thing, but the filters were all pretty bad and the oil (despite being at operating temp) was like a thick sludge at the base of the oil pan (actually stuck to the drain plug!) Looked really nasty.
Running Rotella T6 5W40 Synthetic now. Took about 14 quarts of it, just like y'all said! Here's hoping it helps the truck drive more smoothly!
I've found 2 easy ways to do it.
1) Run your fuel level down to 1/4 tank.use one of those portable automotive ramps to pull the front tire up on. That will raise the filter higher than the fuel in the tank so when you drain the water separator almost all the fuel will drain out of the housing.
2) Make your Wife do it, that way you won't get any fuel at all on you.
GeneLaw1
05-16-2012 01:06 AM
iunderpressure
04-24-2006 09:26 AM
