Need gearing opinions....
Planning out my new course of action for my build(waaay different direction). I`m currently researching how to make this all come together, but the plan as of now is:
`69 240ci six cylinder(maybe upgrade to a 300 later)
NP435(not sure on clutch linkage)
Manual shift BW1356
1/2 ton axles(D44/9in) on leaf springs
35" tires
This truck will see trails, and minor mud(no 4ft deep pits for me), along with some street and hauling duties. Nothing major like towing a car twice a week or anything, just regular truck stuff. I think 35`s are a good compromise for the intended use.
What I am unsure of is the gear ratio in the axles. I have never had a rig with a low first gear like the 435. 3.54s would be easy to find in the axles already, but I don`t want to be unhappy with my gear ratio.
So, anybody who has or had a rig similar, give me some opinions on what gear ratio you like.
Thanks,
Manual shift BW1356
35" tires
Thanks,
Eeeeeh.....
A 240/300 wont rev much past 4000rpm and makes most of their power below 2500.
I have 3.50 gears and 33s on my 79 150 with a fairly hopped up 300 and a 435. 1st is still useless and i get good mileage(15-16mpg with a 4bbl)while keeping the ability to pull hell off the hinges with that 6.xx:1 first gear
All this being said id go with 3.93 or 4.10s for 35s. I would not regear the 44 below the carrier break
Carry on, thanks to those that have posted(hav24wheel, 77mud and alpha/omega).
idk that id go 5.13's with something thats gonna see more hwy time than deep nasty mud, I do however run 5.13's in the race truck but its pretty much for mud only. Id go minimum of 4.11's mainly because you mentioned towing and going down the hwy towing you dont wanna kill it cause its geared wayyyyyyyy to 'high'
RPM= (Gear ratio x MPH x 336) / Tire Dieameter
If your gonna run on the highway more I would assume your gonna want to run at about 2000 RPM
2000 = (GR x 55 x 336) / 35
GR=(2000 x 35) / 55 x 336
GR= 3.79
So to run at 2000 RPM on the highway you need 3.79 Gears. But that will give you the best on road performance (IMO). If your looking for power on the trails and in the mud Your obviously gonna want to run lower.
For reference here is what your setup will give you running lower gears on the highway :
Running 4.10's you'll run 2165 RPMs @55MPH
4.56's You'll run 2408 RPMs @55
and 5.13 you'll run 2708 PRMs @55
GR= 3.79
