4.9L MPG
Old Oct 22, 2012 | 11:20 AM
1986F150six's Avatar
1986F150six
4.9L MPG
1986 F150 with 4.9L [160,150 miles], SROD transmission, 3.08 rear gears and 215/75 X 15 tires.
Duraspark conversion with Carter YF donated by a 1970 F350; stock exhaust with both original catalytic converters, but no EGR. The distributor has been recurved.
I drive about 13 miles one way to work with many stop signs and traffic lights for the 1st 5 miles and then farmland @ 45 mph for remaining 8 miles. On the weekend, I drive short trips in town, running errands, etc. I drive very conservatively, rarely exceeding 2200 RPMs and normally in the 1500-1700 RPM range [no lugging].
7/31/12 16.24 hot w/AC
8/8/12 17.16 hot w/AC
8/17/12 17.39 hot w/AC
8/24/12 17.58 hot w/AC
9/1/12 15.91 hot w/AC
9/10/12 17.70 hot w/AC
9/17/12 17.73 hot w/AC
10/2/12 17.33 warm
10/9/12 16.10 cool
10/16/12 16.97 cool
10/20/12 18.56 cool + hwy
For the last tank, the wife and I took a little drive to a town ~ 45 miles away. Most of the drive is highway @ 55-65 mph. I averaged the two tanks preceeding this one [due to the change in weather] and came up with 16.53 mpg. I had driven approximately 135 miles on this tank before getting on the highway and I filled up @ 231.4 miles, so I drove about 96 highway miles. I did a little math and figured that the truck was getting about 21.5 mpg in order to pull up the average of 16.53 to 18.56 in 96 miles.
Each Winter, I notice the same drop of approximately 1 to 1.5 mpg. This probably can be contributed to by the choke staying on longer, the engine being less efficient at lower temperatures and maybe the gasoline being blended differently for cold weather.
Old Oct 22, 2012 | 11:26 AM
Grubbworm's Avatar
Grubbworm
We just took our truck to the North Georgia Mountains for the first week in October. Some highway, some town, mostly hilly country roads. We averaged 17mpg for the whole week. My truck is mostly stock.
Old Oct 22, 2012 | 12:31 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Most factory odometers are off a little bit as well.
Mine is off .05 less every mile, which is pretty accurate for a mechanical speedo/odometer.
In 700 miles though that can add up... 700 x .05 is 35 miles.
If you go 700 miles and burn 38 gallons = 18.42
If you go 735 miles and burn 38 gallons = 19.34
etc... I would find out how much your odomenter is off, either slow or fast and factor it into your mileage estimates to be more accurate.
Old Oct 22, 2012 | 01:54 PM
aic's Avatar
aic
That's pretty good mileage I think. I tow mowers around town all week and average 10.5 mpg with a 4.9/np435 with 3.73 gears, which I don't think is all that bad.
Old Oct 22, 2012 | 02:34 PM
1986F150six
Your mileage reflects the engine being worked. All of my listed mileage figures are with an empty bed [most of the time].
Old Oct 23, 2012 | 09:36 AM
Gary Lewis's Avatar
Gary Lewis
1986 - That's the most accurate report I've seen on MPG. Keeping track of it that way is really the only way to do it, and I applaud you. That's great MPG as well. Beats the goodie out of the 15 I turned in yesterday, but then Dad's truck might have the edge for towing, hauling, or maybe even off-roading.
As for the odometer, I'm pretty fortunate there. I tested it yesterday over a 20.000 mile stretch of highway and it was off .07 mile, which is an error of .35%. In other words, over my run of 260 miles yesterday it was off .9 miles.
Old Oct 23, 2012 | 10:49 AM
1986F150six
Thanks, Gary! I appreciated hearing your thoughts. For those that don't know, Gary has, I believe, a 351 in his "Dad's Truck".
Now, for a little bit of nonsensical reasoning, brought on by your mentioning having the edge on towing, hauling, off-roading, etc.
I am going to make assumptions regarding the horsepower made by three sized engines and come up with a "fun factor"...
300 = 120 hp divided by ~17 mpg = 7.1 hp per MPG.
351 = 250 hp divided by ~15 mpg = 16.7 hp per MPG.
460 = 300 hp divided by ~10 mpg = 30.0 hp per MPG.
I will present this as being a value for "fun factor".
So, in conclusion, I agree with you that you DO have the edge and it makes me feel that my truck's "superior" mpg number is perhaps due to a smaller and less efficient engine which supplies an output closer to the actual power required to get to and maintain a desired road speed such as 55-65 mph, where as the more powerful [and FUN] engines have more power than is needed???
Old Oct 23, 2012 | 01:21 PM
81-F-150-Explorer
Yes, that is extremely accurate.
In 260 miles, mine is off by 13 miles. It would read 247.
Hmmm, you would have to reason that you were getting maximum horsepower when you were getting maximum fuel MPG wouldn't you? Which wouldnt be accurate, but you basicly said as much...
What would really be interesting is torque figures divided by mpg. That would be more accurate (more or less). I would like to see the 302 figured in for fun as well.
Old Oct 23, 2012 | 03:47 PM
Gary Lewis's Avatar
Gary Lewis
Interesting way of looking at it. And, I think your reasoning that the closer one gets to required power (neatly side-stepping the HP vs torque discussion) equalling available power the higher the MPG. IOW, an engine that takes an infinite length of time to get to the target speed is no fun but as efficient as is possible.
And yes, I not only have a 351 in Dad's truck, I have the dreaded 351M in Dad's truck. And, I like it a bunch! In fact, I actually have two of them - one stock and sitting on the side, and one mod and in the truck. The stocker got 10 MPG and had no personality, no "fun". The one in the truck is fun and decent on mileage, with the most current reading being 15 MPG on a highway run.
The problem is that my engine's torque figures aren't available as it isn't stock by any means, but I don't know what cam is in it to turn to the manufacturer to determine what the power would be. I wish I did know.
Old Oct 23, 2012 | 04:42 PM
1983F1503004x4's Avatar
1983F1503004x4
Looking at these figures, one would assume that more gas is being used up because more power is being made, regardless of whether or not it's needed (ergo, cruising). Of course, I'll say that displacement is the main factor regarding gas mileage with these old trucks. That, and how well the fuel is mixed.
So are you saying that once I'm finished with my 300, I can expect close to 15 miles per gallon?
Old Oct 23, 2012 | 09:11 PM
Galendor's Avatar
Galendor
The difference in summer and winter might also be due to the seasonal "blends" of gasoline changing. But I don't fully understand what changes they make.
I think technically you have the TOD transmission (Top Overdrive), the SROD (Single Rail Overdrive) was the name for older transmissions that have external shifting rails on the side. I could be wrong in my interpretation, but my 1986 factory manual calls our tranny the TOD (reverse is to the right and down, not left and up like the earlier "Tremec" SROD).
Old Oct 24, 2012 | 08:16 AM
1986F150six
Thank you for correcting my mistake!
Old Oct 24, 2012 | 09:25 AM
Galendor's Avatar
Galendor
No problem, it is a common one. Took me a long time to realize the correct name myself. If you have ever driven one of the earlier "Clark" or "Tremec" SROD's, Reverse is kind of strange to shift into (left, up). Kind of like towards you and up is Reverse on a 3-on-the-tree, maybe weird only until one gets used to it.
Very good gas mileage by the way, as good as can be expected. Mine gets about the same, although I haven't carefully determined that the right way like you have.
Old Oct 24, 2012 | 10:08 AM
Gary Lewis's Avatar
Gary Lewis
In the winter the oil companies go to a more volatile blend of gasoline, meaning one that will evaporate more quickly. That's because it is harder for the fuel systems to turn the gas into a vapor in the winter, meaning it is harder to get an engine started as they run on vaporized fuel and not liquid fuel.
Or, another way to look at it is that our emissions of vaporized fuel would be much larger if they didn't go to a harder to vaporize fuel in the summers. Many states have set limits for the volatility of fuel that can marketed at different points in the year.
Old Oct 31, 2012 | 09:08 PM
cartmans_twin's Avatar
cartmans_twin
first off I know this will get a lot of BS calls. but when I'm tooling around town, I get about 22MPG in my '86 W/4.9. on the highway I get roughly 27 MPG. My poor truck is too high geared. it's an '86, F150, 4X4, T-18, NP208 W/ 3.08 Gears on 235/85R16's I don't know how far my odometer is off, so I have to use my GPS.
