How Fires start.
The switch is easy, Motorcraft YH-2. The socket is another story. You have the 73-77 socket. This is different from the 78-79. When I was looking for a replacement for mine ('73) I ran into the same problem. There are plenty of the late model sockets around, easy to get. I saw the exact same socket priced from $2.99 to $36.95 (!). I also saw a lot of these listed as fitting the '73-'77, they DON'T. I never could find the correct socket. Fortunately, at the time I must have been having a brain freeze, this plug is part of the main harness, I was looking at my donor's plug, all melted. Then it dawned on me, look at the plug in the Pumpkin's harness, THAT'S tho one I want to use. It was fine so I dodged a bullet on that one.
Funny it's been ditto so far with the connector, my switch still works but I figured anything power has to pass through to get to the blower motor needs to be in the best condition. I guess I could use seperate connectors as much as I dislike that. I'll keep looking EDIT-Mike & grinnergetter, I just saw your last posts! Thanks
Thanks Mike,
If the wires are still okay and the plug isn't melted really bad, you could transfer the wires and terminals to the new plug.
The terminals have a little tab that, when depressed, releases the terminal from the plug housing. I took a cheap small screwdriver and ground it down so it would fit in the tab release hole. To release the terminal you insert the screwdriver in the hole, pry towards the terminal and pull on the wire.
It's not too clear in the picture, hard to hold camera, plug and screwdriver all at the same time, but the screwdriver is depressing the little tab on the terminal that you can see in the second picture.
With any luck Grinner will have the plug.
I'm not having much luck, my other thought is to try the guys over at "Painless" and see what they come up with but i think these connectors are still needed when they supply a harness.
If you think there is a chance at JY then Please!! Everything around me has been turned into patio furniture, Thanks PM me when needed
on
1 Post
When your wires/plug melts like you show in the picture, it is almost always a loose connection, weather at the plug itself or in the switch. If the problem was in the connections of the plug it more than likely ruined the switch as well. I'd change both. A bad blower motor could have magnified the problem, but if you had not had a bad connection somewhere, it would not have melted like that.
#29
