6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
turbo back exhuast or down pipe back?
Old 10-20-2012, 12:28 AM
tuffnufly81
tuffnufly81 is offline
tuffnufly81 is starting off with a positive reputation.
Hello,
Im fixing to bite the bullet and do upgrades, tuner, exhuast, intake, and EGR delete. Was wondering about turbo back or downpipe back and how hard is it to remove the stock down pipe. I read on here that you have to cut the factory down pipe to get it out.
O and 4" or 5" exhuast?
thanks
Old 10-20-2012, 08:12 AM
slowmans's Avatar
slowmans
slowmans is offline
slowmans has a good reputation on FTE.slowmans has a good reputation on FTE.
If your ever going to have to return to stock for inspection/emmissions reasons, I would just do a delete pipe....If not then turbo back.
Old 10-21-2012, 10:09 AM
StanleyZ's Avatar
StanleyZ
StanleyZ is offline
StanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to behold
I agree. Unless you intend to drag race I think you will find that removing the DOC back and adding any tune or even a stock tune will give you plenty of new found power.
A number of people on this forum have reported problems with after market air filters and knowledgable diesel guys say unless you're adding 200 or more HP the stock filter is plenty adaquate.
Plus, once you cut the down pipe it's over. No going back without pulling the engine or finding an extremely talanted welder.
Old 10-21-2012, 12:58 PM
UGA33's Avatar
UGA33
UGA33 is online now
UGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud ofUGA33 has much to be proud of
IMO, down pipe back 5".
Old 10-24-2012, 11:03 PM
FivePointo's Avatar
FivePointo
FivePointo is offline
FivePointo is starting off with a positive reputation.
I did turbo back and went 4" out the back. I wish I'd have just done 5" and left the down pipe stock. The down pipe was a nightmare, it's not a 1 man job and it's certainly not this man and his wife job. I've been married 20+ years and heard my wife say words I am unsure sailors know.
Old 10-26-2012, 06:59 AM
Laner's Avatar
Laner
Laner is offline
Laner is starting off with a positive reputation.
This is good information! I will be ordering a mini maxx and down pipe back exhaust soon as my warranty just ran out. I am not sure if I want to go with 4 or 5 inch.
FivePointo -why do you wish you had went with 5" instead of the 4"?
Old 10-26-2012, 03:38 PM
StanleyZ's Avatar
StanleyZ
StanleyZ is offline
Let's think about it a minute. The purpose of the larger exhaust is to allow more exhaust (air) to exit the turbo. If the down pipe is 3.5 inches, which I think it is, then what would a larger pipe behind that do for you. Other than looking more robust at the end of the tail pipe it can't do anything. It is down stream from the obstruction. But, I promise that when you start your truck for the first time after the tuner and delete you will be impressed with the power, even with a stock pipe.
Old 10-26-2012, 04:26 PM
FivePointo's Avatar
FivePointo
No logic to me yea the stock unit is 3 1/2 in
Old 10-26-2012, 04:46 PM
RM2738's Avatar
RM2738
RM2738 is offline
RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.
I've got news for everyone. The OD may be 3.5" but the ID is far from it. I'm not gonna say whether or not you should do turbo back, but I'll be you will after this:
<a href="http://s68.photobucket.com/albums/i34/westwoodlands/?action=view&current=AD5358B9-AC3C-4352-9B57-3A9F3A6BDFAF-1006-00000068E13B9887.jpg" target="_blank"><img src="http://i68.photobucket.com/albums/i34/westwoodlands/AD5358B9-AC3C-4352-9B57-3A9F3A6BDFAF-1006-00000068E13B9887.jpg" border="0" alt="Photobucket Pictures, Images and Photos" /></a>
Old 10-26-2012, 04:58 PM
Laner's Avatar
Laner
Laner is offline
What is the sq inches of area in that cross section vs a 3-1/2 or 4" round pipe?
Old 10-26-2012, 05:03 PM
RM2738's Avatar
RM2738
RM2738 is offline
Stock: 7.36"
3.5: 9.62"
4: 12.57"
Old 10-26-2012, 05:06 PM
RM2738's Avatar
RM2738
RM2738 is offline
5" is 19.63"
So with that stock down pipe, you're really restricting airflow. The cold side CAC pipe is similar in its restriction.
Old 10-26-2012, 05:43 PM
StanleyZ's Avatar
StanleyZ
StanleyZ is offline
Originally Posted by RM2738 View Post
Stock: 7.36"
3.5: 9.62"
4: 12.57"
I hope that math isn't based on that picture above. So what is the ID on a stock pipe? I can tell you I have plenty of power with the stock exhaust (absent the DOC/DPF). But if you want to drag race it then I guess changing the turbo back and the air box would help. Me, I'm just towing my trailer at 60MPH and I have more than enough power for that.
Old 10-26-2012, 07:06 PM
RM2738's Avatar
RM2738
RM2738 is offline
My math is calculated by imputing the image into AutoCad, tracing the image, scaling it based on the narrowest measurement that i took and the asking the software to calculate the area.
Old 10-26-2012, 07:33 PM
RM2738's Avatar
RM2738
RM2738 is offline
I can also tell you that power wasn't noticeable whatsoever. It was the EGT's that really improved after the DP was installed. With just a delete pipe, I could defuel at 1450 pretty easily. After a turbo back system, I rarely reach 1200 now before defueling because of boost PSI.
Quick Reply: turbo back exhuast or down pipe back?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
