6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
turbo back exhuast or down pipe back?
Old 10-26-2012, 08:58 PM
StanleyZ's Avatar
StanleyZ
StanleyZ is offline
StanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to behold
Originally Posted by RM2738 View Post
I can also tell you that power wasn't noticeable whatsoever. It was the EGT's that really improved after the DP was installed. With just a delete pipe, I could defuel at 1450 pretty easily. After a turbo back system, I rarely reach 1200 now before defueling because of boost PSI.
You gotta be an engineer. My sons one so I recognize the thought process. But, what were you doing to get to 1450 EGT, i don't think I've ever been close to that, even pulling some of those passes out west. And my rig is 25,000 plus on the scale.
Old 10-26-2012, 09:19 PM
RM2738's Avatar
RM2738
RM2738 is offline
RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.
Residential/Commercial Contractor actually.
I didn't hit 1450 regularly, but I could do it easily. I had to put a few sports cars in their place. Mustang GT, Corvette and a 370Z to name a few.
Old 03-18-2013, 08:32 AM
countryboy73703's Avatar
countryboy73703
countryboy73703 is offline
countryboy73703 is starting off with a positive reputation.
downpipe question
alright so I'm reading around and came across this thread, and I have a quesation. why do you have to cut the stock DP out? does it just not twist out and stuff? and if thats the case, then how is it that you can install the aftermarket down pipe? Also, turbo back exhaust is actually a after market DP and back kit, correct? and a DP back kit, keeps the stock DP and replaces everything aft? correct.. too many threads being read and some people are not 100% on what they are saying, so it gets confusing.. thanks...
Old 03-18-2013, 08:45 AM
RM2738's Avatar
RM2738
RM2738 is offline
After market DP's are usually two pieces. People have gotten the OE DP out w/o cutting, but I couldn't.
Old 03-18-2013, 01:14 PM
FivePointo's Avatar
FivePointo
FivePointo is offline
FivePointo is starting off with a positive reputation.
DPF back vs Cat Back
Mine has been off so long I forget the architecture but I think it goes down pipe to cat to dpf to muffler. I don't know why you'd just go cat back, which as I said just replaces the cat and muffler. Just replace it all.
Old 03-18-2013, 05:54 PM
StanleyZ's Avatar
StanleyZ
StanleyZ is offline
If you are talking pipes and mufflers then Down pipe (DP) back would be remove CAT and DPF and Tail pipe and muffler.
Turbo back would be Down Pipe plus what you removed above.
Removing Cat and DPF (tuner required) is the best thing you can do for the 6.4L truck. If you do that, you will have more power than you ever need and will be wasting money doing anything else to the intake or exhaust. unless you are going for drag racing or sled pulling.
If you do not remove the DPF anything else you do is just a waste of money.
If you want to remove other stuff then get it all.
Adding a larger pipe DPF back does nothing but reduce your bank account.
Hope I covered it all.
Jzinkiewicz
05-06-2008 07:03 PM
evilperson86u
06-03-2007 08:02 PM
bckmster1
General Diesel Discussion
09-13-2006 05:21 PM
t.j.g.
05-19-2004 05:23 PM
Pastmaster
09-14-1999 04:08 PM
Quick Reply: turbo back exhuast or down pipe back?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
