5 speed for ford 400 long block
NEED HELP!!!!!!!!
i have a 1968 ford f100 ranger and i am looking to put a ford 400 long block with a five speed is my dream. However, I am having trouble finding any performance options for the 400 as well as a 5 speed that will bolt up to the 400 any ideas and input would be amazing thanks
Performance options for the 400 are mostly aftermarket as it was never a performance engine as OEM. You can find everything you need to turn it into a firebreather here:
TMeyer, Inc. Precision Automotive Machining
The minimum to make it a runner is a cam change, along with whatever the cam change requires spring wise etc.
As for a 5 speed, the ZF 5 speed will bolt up, but some mods are needed to deal with the pilot bearing. More than you'll ever want to know here:
https://www.ford-trucks.com/forums/1...zf-tranny.html
If you want a performance 5 speed, you are looking at a TKO or T56 6 speed, with an aftermarket bell.
These folks will be more than happy to help you in your quest:
Modern Driveline - TREMEC T5 / TKO Transmission Conversion - 5 speed & 6 speed solutions to swap your Ford Mustang, Falcon, Cobra, Hotrod into Overdrive! Performance Parts
Having said all that, what engine is in it and have you ever heard of the 351w?
right now there is a 352 big block which came in the 67 but not the 68 im thinking it has a reman plate on it so its a fairly new motor and runs ok but with the factory 3 on the tree. It screams any time i take it on the interstate and do alot of traveling back and forth on the interstate plus i love 5 speeds
honestly in the middle i want a good bit of power but i also drive the truck everyday because i love old trucks. i also have complete 400 that i am just put on the engine stand and am going to tear into to see the condition i dont need a monster but would like the truck to have a little more power the 352 runs like a top and fires every time but i would like to have a bit more power and torque
NEED HELP!!!!!!!!
Here's another one from Hot Rod magazine. How does 556 lb-ft of torque and 496.7 hp sound to ya?: How We Got Over 497 hp from Ford's 400M Engine - Hot Rod Magazine
Yeah, I thought so.
2x on Modern Driveline.
Stock, the 400 is a pooch. Lots of potential, as you can see from the links provided. Not cheap--figure $6000 to make that high powered job.
JMO but I would stay with the 352 for now.
Do you have a link to the info on putting a ZF up to an FE? I'd sure be interested in that swap.
i decided to stick with the 352 and find a 4 or 5 speed to put behind it any suggestions on what to go with as far as trans or rear end gearing. I do do alot of highway and interstate driving which is why i am trying to get away from the 3 speed. and also any idea what rearend comes stock in a 68 f100?
towtruck1
01-03-2007 10:46 PM
77lowrider
05-27-2003 06:31 PM
82_4x4_swap
09-26-2002 06:50 AM
