Looking for info on a transmission swap
The column bolts up to the pedal assembly but if you pull the seat out it may go low enough to get the pedal support out.
The part number is 7A621...
^That picture shows my gold colored brake pushrod I shortened and used
for a clutch pushrod...
Alvin in AZ
The plug at the clutch M/C is the clutch safety interlock.
(serves the same purpose as the NSS on an automatic.)
a) flexplate for an automatic
b) flywheel for a standard
One difference here is the engagement depth of the starter bendix gear.
You'll need a starter for a manual if you didn't get it from the donor.
(ask me how I know!)
^check it out, they are the same- except the manual one has a "cast in"
spacer.
My '75 F150 didn't have any of that silly stuff and never had a problem
with in 38 years (come Feb 14, 2013). ;) so I jumpered that stuff out
on the '91 Bronco. The manual-EEC needs to know the clutch pedal is
pushed-in on "pin 30" so it can drop to idle quicker. :) YMMV on that. ;)
Don't even think about pulling or stabbing a transmission without 'em... ;)
^made those in '79 and still using them since the 351w uses 7/16" bolts...
Alvin in AZ
'75 F150 360FE +T18
'91 Bronco 351w +2wd ZF +'90 F250 EEC :)
Ain't these pur-dy... ? :)
E4od = ~230# = ZF = ~145# + flywheel and pressure plate = ~230# too
And I'll retake that dangged fuzzy picture too. :)
You guys seen the shape of the pushrod and its stud, just know that
188k miles on a company truck (never was oiled or anything) and the
firewall on that truck is good as new! :) So, like we've fiNgured;) out
before that plate does a great job of preventing the firewall problem.
Ford made a couple more versions depending on how bad the firewall
was (from then not installing that plate) to bolster the firewall, nothing
a guy (and/or a buddy) couldn't make just as good or better, IMO.
Seems like there's a gasket that comes with a new master cylinder?
^Heck, if so, there's your template! LOL :)
Alvin in AZ
My steering column bolts up to/is supported by the pedal trunnion casting.
You can see the two large holes on the right side of this pic.
How do you get it free without dropping the column?
(maybe later versions were different?)
#29
#30
If there is no difference why are there different Lester numbers for an automatic (3226) and a manual (3225) 7.5l starter???
I have a 5 page thread from last year about 460 starter problems.
I think I've seen all this before...
Ford starter pdf
Ford starter pdf
