Strange Dashboard Issues.
Old 10-20-2012, 02:23 AM
mazer's Avatar
mazer
mazer is offline
Hello everyone.
I've been having issues with my 2004 F-150. This has been going on for a good 3 years now but I have yet to get it looked at professionally due to financial issues.
When I drive, the dials on the dash (Speed, etc) usually end up zeroing out. On top of this, all the warning lights click on with a loud beeping sound (parking break, check engine, seatbelt, oil). And finally if I am using the A/C when this happens, the A/C stops blowing cool air and starts blowing humid warm air.
I generally end up smacking the top of my dashboard to cause them all to go back to normal but this usually only lasts for a good 5-15 minutes before it happens again.
Finally, ever since this happened, the Milage stops displaying. The only time I get it to display is if my truck needs a jump (I have a new battery currently) and then it turns on for maybe 4 hours before turning back off (the milage counter)
I've been told this may be a cluster issue?
Any assistance?
Old 10-20-2012, 12:54 PM
Papa Tiger's Avatar
Papa Tiger
Papa Tiger is offline
Temporarily Deactivated
Received 3,425 Likes on 2,340 Posts
You are probably suffering the old water leak on the electrical fuse box causing corrosion. Probably a windshield leak. Look of blue/green corrosion usually leads you below the source area of the leak. Also look for a loose bad connection. Does it seem to be worsening over the time of the problems.
Stevem8
02-10-2017 07:07 AM
Inthswamp
1997-2006 Expedition & Navigator
12-24-2016 01:55 PM
shortbusted
11-22-2010 06:07 PM
Taurkon
05-26-2009 07:14 AM
clydesdale558
01-20-2008 05:04 PM
Quick Reply: Strange Dashboard Issues.
