Advanced Adapters - 78 f150
Hi All,
Back in 99' I converted my truck from a 460 with a C6 over to 460 with a New Venture 4500. I hate the clutch. It is brutal to press down. just curious if anyone else had made this conversion. I guess I am sick of it and want to switch back to a C6.
Curious what people think out there?
Thanks!
Chris
Thanks!
Chris
Not sure how much help this will be on your setup but it sure made a difference on mine.
If you look at your linkage you should have a vertical rod that has a 90 degree bend on each end ( pedal lever rod ). My rod was worn bad and it also wallowed out the holes they went in. I made a new rod but instead of the 90 degree bends I used heim joints.
I can't say how much of an improvement, if any, it would be over new parts but it made a big difference over my wore our parts.
