Rear Brake Caliper
Rear Brake Caliper
I completed a rear brake job yesterday on a late model 99 F250 SD 4x4.
I was surprised to find that the driver side rear caliper had 2 bleeder screws.
This is the first time I have found two bleeder screws on a caliper. The replacement caliper had only 1.
My questions would be: Why the use of two bleed screws on a caliper? Has anyone else found two screws on their caliper while rebuilding the rear brakes?
Was the use of two bleeder screws a Ford caliper?
Thanks
Jeff
Thanks
Jeff
Thanks
Jeff
Thanks
Jeff
The two bleeders allowed the same part to be used on both sides of the same axle. Interchangeability and fewer parts being manufactured was the reason.
The problem is that the aftermarket sees only one part number, and only makes one part with one bleeder screw, usually in the wrong place in my experience.
Thanks
Jeff
Thanks
Jeff
bigtexan99
10-24-2014 01:14 PM
