Anyone have a wheel bearing get destroyed in a split second?
I drove my truck to work and all was fine. I went to pull out after work and it felt like the whole front wheel was going to lock up, grinding, banging, noisy. I quickly pulled it into a gas station and we jacked it up to see metal shavings and see the play in the wheel. Im getting it towed and going to tear into it tomorrow. Hopefully its just the bearing assembly and didnt take the hub with it. Anyone else see this before? I thought bearings were suppose to give you a warning before they went? The the way its on a 2000 F350
National LM102949 - Taper Bearing Cone | O'Reilly Auto Parts
Can't you just change a bearing? A quick parts search shows there is a simple bearing on 2001 7.3.
And actually to the OP if you can wait, you can pick up Timken unit bearings at Rock Auto, or I found them at Autozone(Who I hate) but for 150 bucks each, hard to pass on them.
My last one went that way.Drove home about 25 miles from a job site and the next morning it locked up 100 yds down the road.
It did lock up for a split second 500-1000 miles before. I thought I hit something in road that I didn't see and it jerked hard to the left. I pulled over and couldnt find anything on the truck or anything in the road that could have caused it and forgot about it until locked up again. The second time when it broke free it was grinding.
Timken was the OE IIRC.
Are you single rear wheel or Dual?
Here is Rock Auto if you can wait http://www.rockauto.com/catalog/raframecatalog.php
If you need one local and have an autozone Timken/Wheel Bearing/Hub Assembly-Front (515020) | 2000 Ford F350 Super Duty P/U 4WD 8 Cylinders F 7.3L Turbo Diesel | AutoZone.com
Even if you don't have front ABS, get the one with it, it's usually cheaper and you can grease the bearing through the ABS hole.
Just replaced one on my 2002. I got a Timken from AutoZone. I think it was about 185.00 plus tax. They have them for ABS, non-ABS, fine thread and course thread lugs. The non-abs fine thread was almost $300.00. It was about a 4 hour job for me. Not real hard, just quite a few big nuts and bolts and a pretty heavy hub assembly.
The search returns: https://www.ford-trucks.com/forums/4...-bearings.html
Ford High Temperature 4x4 Front Axle and Wheel Bearing Grease E8TZ-19590-A
Its step 5 of the installation. You need to check the specs on the grease your looking at compared to ford's req.
Here is the Annual grease list, which might be a better choice, as it appears to have different grease types named, and directions for all of it.
https://www.ford-trucks.com/forums/9...-bearings.html
