how much can i tow
  #31
Old 10-10-2012, 12:25 PM
jroehl's Avatar
jroehl
jroehl is offline
Originally Posted by dakota1820
hey guys my door tag does say 8650gvwr . ford told me today though that the gcwr is 6450.... i am confused. i could upload a picture of the door tag but i promise it says 8650 gvwr. the truck does have five leaf springs the heavy duty cooling system rear sway bar ect.... but i am confused i just want to know what it can tow and what is the payload.
Ain't a soul going to believe this until you post a picture of the door tag.
Jason
  #32
Old 10-10-2012, 12:50 PM
danr1's Avatar
danr1
danr1 is offline
Jason
Possible it says that but wouldn't necessary make it correct for that truck.
For example my 94 F250ies door sticker shows a GVWR rating of 6250# however the trucks GVWR is 8600#, it has the cab from a F150 on it now.
Perhaps someone at some point and before the op bought it, put the cab from a F250 on it?
Then that extra 50 comes into question tad bit, F250 standard cab = 8600#, same truck with an extended cab = 8800# no "50" tacked on to it?
  #33
Old 10-10-2012, 02:23 PM
Conanski's Avatar
Conanski
Conanski is offline
Originally Posted by Diesel_Brad
Thats odd. My CCLB 460 5spd truck weighs 7200lbs
Nothing odd about it that's an F350.. everything below the body of an F150 is much smaller and lighter. My truck is right at 5k on the dump scales.
  #34
Old 10-10-2012, 02:28 PM
Conanski's Avatar
Conanski
Conanski is offline
That's my thought, no F150 from this era has a GVWR that high.
  #35
Old 10-10-2012, 03:30 PM
blkF250HD's Avatar
blkF250HD
blkF250HD is offline
IIRC the highest an F150 ever went was 7700 for the LD F250/ F150 7700 in the late 90's.
  #36
Old 10-10-2012, 03:33 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
And that is what I figure a super cab F150 to weigh if a reg cab weighs 4400
  #37
Old 10-10-2012, 03:43 PM
Evan_P's Avatar
Evan_P
Evan_P is offline
Last time my truck was on a scale was at the dump. Weighed in at 5370 with me and my dad in the truck. 92 EC Flareside 4x4
  #38
Old 10-10-2012, 03:59 PM
dakota1820's Avatar
dakota1820
dakota1820 is offline
i think the tag isnt original. everything on it is right though except the gvwr part of it. ford said today that my gcvwr is 6450. so i can tow only 2200lbs? seems pretty wimpy to me. still not sure how much payload i can have though
  #39
Old 10-10-2012, 04:46 PM
Diesel_Brad
What gear ratio do you have?!?!? THAT is the deciding factor we need to know. On the door jam sticker under AXLE it will have a letter and number
  #40
Old 10-10-2012, 08:26 PM
jroehl's Avatar
jroehl
jroehl is offline
...or a two-digit number if the rear axle has an open differential.
Jason
  #41
Old 10-10-2012, 08:38 PM
dakota1820's Avatar
dakota1820
It has 3.08 gears
  #42
Old 10-10-2012, 08:46 PM
GNR22's Avatar
GNR22
GNR22 is online now
Fabri-cobbler
Just to add numbers into the weights of trucks and stuff, my F250 with a toolbox full of chains, stereo equipment, and the monstrosity of a bumper on the front weighs in at 6100lbs without me in it.
  #43
Old 10-10-2012, 09:14 PM
blkF250HD's Avatar
blkF250HD
Sounds like you have the "weekend warrior" F150. I'd feel confident towing an average size fishing boat, a pair of sleds, or a utility trailer with that set up, but nothing really large or heavy.
  #44
Old 10-10-2012, 09:39 PM
Conanski's Avatar
Conanski
Conanski is offline
It has 3.08 gears
With a 5.0!! I feel bad for ya.
  #45
Old 10-10-2012, 09:46 PM
dakota1820's Avatar
dakota1820
I had a 300 a couple yard ago and hated it the. 302. Will will smoke the 31s in it all day long. I am not sure if maybe they changed the gears . But its much stouter thatn the 300i had. That truck made power early but ran outta steam to quick and got stuck everywhere. Total boat anchor
Quick Reply: how much can i tow
