351w rebuild or not rebuild
I have a 351W out of my 1996 Bronco with 190,000 miles. Doesn't burn oil, no knocking, runs great. Pulled motor to replace front/rear seals, freeze plugs, oil pan gasket, timing chain. With this mileage is it recommended to rebuild motor? On a budget, should I just fix the above mentioned parts and install motor as is, or should I contemplate a complete rebuild? Got a quote for $1700. Any suggestions with other options on which way I should go?
Thanks!
Thanks!
Thanks!
Thanks!
including new oil pump & name brand parts (such as clevite, etc)- I would swag $600 for the parts kit, and figure $150 per head for a valve job plus parts (if valves & springs need to be replaced) for that.
robjs111
09-26-2012 01:36 PM
Blackwaterforge
10-10-2008 09:34 PM
