Looking for some opinions.
Looking for some opinions on the 6.7L twin turbo diesel engine. The salesman told me that this diesel engine was not effected by short trips like the older diesel engines were for not being able to get hot enough to obtain normal operating temp and causing engine wear.
Any time any engine starts cold it wears faster than when it's warmed up, short trips are a beating on any engine. The 6.7L isn't a HEUI so it doesn't have the same immediately apparent cold start and driveability issues that the 7.3 and 6.0 have because cold oil isn't being used to fire the injectors, but there's still an EGR, plus a DPF that has to get burned out. Frequent short cold trips aren't going to be good on any diesel, you're more likely to have emissions issues, plus increased fuel dilution of the oil.
Not exactly. It's two sets of compressor vanes on the same shaft. Here's how it works: DualBoost Single Sequential Turbocharger
The rule of thumb I always followed with my 7.3 was 10 miles one way minimum. The new diesels have like states above lots of new tech that requires the truck to get to temp and stay there for some time. You will have DPF and EGR issues as well as contaminated oil with traces of fuel and or water.
In the car business there's another saying, there's an (donkey) for every seat!
Whatever doesn't get oil and water up to temp.
Personally, since I have back-up vehicles if I'm not going to use it long enough to justify the cold start I won't bother cranking it up, because frequency/ total number of cold starts will drive shortening maintenance intervals more so than not getting it up to temp on a short drive; it doesn't matter if it's warm for a minute or an hour, all the fuel got past the rings and all the cold-start wear happened while it was warming up.
