2010 f150 v10 swap. ecu pinout help!
i am doing an enigine swap in a 2010 f150. I am putting a '05 3v v10 in place of the original 205,000 mile 2v 4.6. i am having trouble finding pinout diagrams for for either the f150 or the v10.
i am using the original 4.6 harness and adding additional pins and the coresponding wiring for the extra coils and injectors.
Mike at 5 Star says we should be able to write a tune to account for the extra cylinders.
If any one has the resources to get the pinouts it would be greatly appreciated!
i need the pin outs for the ecu plug on the stock 2v 4.6 engine harness and lets say a 2010 f250 v10 engine harness.
thank you very much in advance.
Barry
Barry
i was unaware of the variable plenum. i am still waiting for the engine to arrive. just another bit to work out.
it should make for a pretty fun truck. it is a standard cab short bed 4x4. it allready runs really decent after tuning. as with every rig i own, i must amke it better. haha.
i will have to start a thread in the v10 forum.
once i get this thing running, it will be getting taken back down and get a compression bump to 10.5 to 1, ported heads and some cams.
