there is a very big difference between a solid 44 and a ttb 44.
and the biggest difference is that a solid 44 axle tube will not stress crack and fall apart.
well, anyone that runs 44 inch tires on a dana 44 axle really don't know much about building a truck
Originally Posted by khadma
This will have to be the FTE Off-road forum theme/mantra.
Reps to you, if they will let me.
I have to put this in my sig.
true but it was a chevy guy..
anyways ttb isnt bad.. people use them all the time.. you need to see where your build is going.. if you plan on going 1ton.. save and go one ton.. if you think 35s or even 36 is it.. go solid 44.. if you plan on staying 33s keep the ttb
Might be time to start newb smashing again. We've been kindler and gentler long enough... we must have some credit saved up or something, should buy us some time before we start getting infractions again..
