Carter YF help
Old Sep 28, 2012 | 07:50 PM
fearfactory's Avatar
fearfactory
Carter YF help
Does anyone know where I can buy the check ball retainer cap/expansion plug for my Carter YF carburetor? The rebuild kit that I purchased from O'reilly, doesn't come with it.
Pictures attached for a better understanding.
Old Oct 2, 2012 | 12:18 PM
fmc400's Avatar
fmc400
MSEE
I don't recall there needing to be any sort of cap there. The air horn gasket should just go right on top (after the check ball and weight go in). Can you show what is telling you otherwise? I assume a rebuild sheet?
Old Oct 17, 2012 | 08:33 PM
PatientZero's Avatar
PatientZero
I'm not the most knowledgeable fellow in the world, but I don't believe that there is one either. If I'm not mistaken, that ball needs to be unobstructed. I'm thinking that it somehow regulates fuel in the accelerator pump circuit. Probably just completely showed my ignorance in this area, but.....
frdf250
Oct 7, 2017 02:49 PM
fred_79f250
General Automotive Discussion
Jun 27, 2016 08:43 AM
fearfactory
Nov 21, 2010 05:22 PM
jaybird
Oct 23, 2008 01:03 AM
78bigunns
Sep 29, 2002 10:42 AM
