A Better Fuel Bowl Lid Gasket
Double Seal Buna-N O-Ring AS568A Dash Number 347.
The key here is that this is not a typical round o-ring, it has four lobes (think of a four-leaf clover for the cross-section). When you have it in your hand it feels and looks more like a square o-ring.
Make sure that whatever material you use will withstand exposure to diesel fuel.
Okay Team I got my o-rings from McMaster-Carr
I just got home and it is after dark, but my McMaster-Carr o-rings were at my door. So, I wanted to give them a try on my fuel bowl and I grabbed my flashlight and screwed one of the o-rings onto my fuel bowl going as tight as I could with hand tightening until it stopped. I started my 7.3L and no leaks, so I am still running the engine to bring it up to warm temps and I will keep an eye on it. The part number that KelV gave us is #90025K557 double seal buna-N O-rings they come in packs of five and they are $9.12. I am sold on these o-rings because I messed around with the OEM bevel o-ring for an hour and had 10 different leaks and a case of the azz. These McMaster Carr O-rings do not require you to have to use a pair of channel locks and risk breaking your fuel bowl/lid. I just checked again and the engine is up to normal temperature, and zero leaks with only being hand tightened...I found my new fuel bowl o-rings. KelV many thanks to you for mentoring us and sending us off in the right direction. I like FTE because there is a wealth of knowledge on this site.
Thanks again...the colonel.
I just want to resurrect an old thread that has become germane to my truck...it's leaking at the fuel bowl lid! I took it off and put silicone grease on the gasket, smoothed a coupla' ridges out on the lid and tightened with a wooden drift and a bfh. Good, so far. I also ordered 10 of the "square" orings from mcmaster-carr. Thanks KelVarnson
I also ordered ten of the square o-rings...
Here is where I am at with faulty equipment. I am an Army Colonel and if I allow faulty equipment to be put in a 2.5 ton or 5 ton army trucks that are carrying troops and the truck breaks down and the taliban shoot and kill the troops then I am not doing my job by forward thinking and trying to work thru fubar's before they happen. I like my 7.3L PSD, but that Ford OEM fuel bowl gasket does not meet the standard and is sure to leave you stranded in some gawd awful place. I will give you additional reports on my McMaster-Carr gaskets, but they are working great. Thanks.
This one is not a lobed (double seal) o-ring, but it is the ultimate material - mil-spec Viton. Same dimensions as the lobed ones from McMaster-Carr. This one is also a little more costly, as you would expect from Vition... $9.13 each.
Link... Online O-ring Store
HOWEVER... here is a much cheaper supply of the mil-spec Viton in the same dimensions for only $2.69 each, ordering in quantities of two at a time. To get the correct price, while referring to the Material Information and Size Information charts, the size required is "-347" and the Material is 75-durometer FKM (black and brown available, but black is slightly less expensive). Since the minimum order quantity is only $5, you can order as few as 2 at a time. Again, though, these are round o-rings, not quad-lobed double seal pieces.
Link... O-Ring Warehouse
#28
#30
