Driveshaft Yoke Question
Without grease, the yoke will get scored, howl like a Basset Hound. The u-joint doesn't look like it been greased since "Tricky Dick" was prez.
If no Zerk (grease) fitting present, there may be a rubber plug in the hole it threads into. This was Ford's better idea: "Lifetime Lubrication." Lifetime, till the warranty (2 yrs or 24K miles) ran out!
Get yourself a grease gun, lube all the fittings. Zerks and grease gun, cartridge of grease available from any autoparts store.
With a two piece driveshaft, all three u-joints are the same, have two different sized cups.
C5TZ-4635-F .. U-Joint / Spicer number: 210392-X / 2 cups are 1310 / 2 cups are 1330 / Available from autoparts stores.
D9TZ-4800-A .. Driveshaft Center Support Kit / Available from Ford.
MSRP: $102.65 // FTE Ford Dealer Parts Dept sponsor horizonpartsguy.com price: $73.91 / Horizon Ford in Seattle (Tukwila) WA
