Anyone have time to help with a "squeal" problem?
2003 Excursion V10 76,000 miles w/ some up north salt exposure. A few weeks ago I would notice a faint squeal / high-pitch whine while driving through the neighborhood on my way to work everyday - but it would quit by the time I got to the open road. Today, the squeal was much worse and kept at it all the way to work at all speeds. I turned off the A/C - still there. The pitch of the squeal goes up and down with engine speed. And will do it in park. Under a good load (if I'm accelerating quickly), it will go away. Over the weekend, I rinsed off the motor and it seemed to make the issue worse. I have a new tensioner pulley and idler pulley on order but I might try shooting a little wd-40 on them to see if the noise goes away until the new pulley's arrive.
Any other thoughts?
Any other thoughts?
When I first got my truck it had a similar noise. I suspected the tensioner pulley, but my dad squirted some Windex on the belt and the noise went away. (Windex works as a temporary lube and evaporates with no residue.) I replaced the belt (which was cracked anyway) and the noise has been gone since.
If you do replace your belt, I recommend Amazon. They have it for $30.11 and no shipping for Prime members.
They also have the tensioner for $43.38.
Good to hear it's fixed.
Over the years that I've had modulars, every few years I hear the tensioner or idler pulley bearings making noise - so I just replace the entire thing, and the belt while I'm at it.
Now that I have a real hydraulic press, next time I'm going to find some heavy-duty bearing the right size and see what I come up with...
