wheel for a 48 ford f2
I recently received a 48 ford f2 that I want to work on as a project.
First thing I guess is get it rolling.
I assume the old wheels have tubed tires, right?.
Is it best just to get some newer style wheels that don't require tubes? Can I get some off a later model ford (50s or 60s?) that will work?
Are there some other options for wheels (somewhere online that they can be bought new if I had to?)?
Anybody use the tubed wheels and tires? Any good reason to do that?
Dick - an F-2 has the same 8 x 6.5" pattern as the F-3s and later F-250s. The stock wheels are pretty hardy, 16" x 6", and very sought after by F-3 guys who are wanting to be rid of their 17" widow maker style wheels. They'll take the whole range of 16" tires that are appropriate for the 6" width. Stu
Very cool, so if you seal the wheel rivets you can use tubeless tires? Yes
How safe is that? As safe as any other wheel.
Also, my other question was are there wheels from later models (50s or 60s) that are tubeless and have the same bolt pattern? Sounds like that is not the case. Any F-250 wheel up to the 1997 F-250 HD model will fit. If your purpose to get more stylish wheels this makes sense, otherwise I see no benefit to doing this unless your stock wheels are damaged, severely rusted, etc,.
I am currently using original wheels on my 37 Ford with tubeless radials. These wheels have a lot of rivets holding the center to the rim. Before mounting the radials I had the wheels sandblasted and painted. I did nothing else to seal the rivets and have had no air leakage problems in the four years the tires have been installed.
