Help! What part is this? 2001 F-150
Old 10-02-2012, 07:02 AM
herfarm's Avatar
herfarm
herfarm is offline
Water is seeping thru the metal block that the bolt is in. We can find the bolt part but not the block part. Pic https://twitter.com/i/#!/Herfarm/med...com%2F3LdSbyMf
Old 11-28-2012, 09:33 PM
ford_devel_dog's Avatar
ford_devel_dog
ford_devel_dog is offline
for starters what engine and got as better pic, use paint to circle it, i got alldata so i can define most anything
Old 12-07-2012, 12:23 AM
mitch1204's Avatar
mitch1204
mitch1204 is offline
I believe you are talking about that brass looking bolt. Actually it's a plug and it screws into the lower intake manifold.
1997 thru 2003 used the same lower intake manifold. But on the 1997 to 2000 I believe that hole is used for the coolant temp sensor. On the 2001-03 they plugged that hole and used what they call a head temp sensor that screws into the back side of the drivers side head.
Usually you use pipe dope or teflon tape on that bolt and is probably your problem. I never seen one crack?? If it did you might get lucky with JBWeld or something similar as there is coolant flowing through there under 16 psi pressure. I just happen to have a 2001 lower intake from an engine swap job I done.
That chrome pipe with what looks like you got epoxy on it is your fuel rail. It connects the fuel line to your injectors which also slides down and bolts into the lower intake.
mustang81
12-16-2018 11:03 AM
Muddy Truck
12-11-2016 11:49 PM
Senor Joseph
1997-2006 Expedition & Navigator
04-19-2015 11:02 AM
thatoneguy_10
01-02-2011 09:55 PM
Reed
13
02-02-2009 06:40 PM
Quick Reply: Help! What part is this? 2001 F-150
