Rear Disc Swap from 2000 8.8" Rear to a 73
I'm pretty sure they won't fit onto the axle tube, and I KNOW the rotors won't fit onto the lugs or inside the 15" rims.
But you can swap the whole new axle under the old truck - the 8.8" is every bit as strong as the 9", and probably more so. If you want the F&R rims to match, have the front hubs drilled for the new lug pattern and get a set of new 16" rims & tires. That's what I'll be doing when my current tires wear out.
Big_Red_Brute
11-04-2014 06:11 PM
Bootlegger's Deluxe
19
11-27-2012 06:14 PM
Eddie
11-30-2001 08:06 PM
