4.0 SOHC Timing Help?
Old Sep 20, 2012 | 11:26 AM
JKolbfleisch's Avatar
JKolbfleisch
So I replaced the chains and guides ... and according to the guides I found, I lined up the camshaft markings parallel to the head surface with it going below the cam-center. Crankshaft is at TDC according to the pin (under timing cover) as well as the sensor marking AND a hanger inserted through #1 Spark Plug hole.
When I do a compression test though .. I'm only seeing like 60-70psi on all cylinders.
What could I be doing wrong? Here's a pic as the chains all sit now.
** I used a micrometer and the camshaft slots are DEAD on parallel to the head!
** I double checked and the crank is 100% TDC!
FordTruckfan89
Nov 11, 2018 07:35 PM
410F-100
Apr 15, 2018 08:23 AM
300zx
24
May 10, 2016 12:43 PM
tripleforce
May 6, 2004 09:36 AM
dougas
Aerostar
May 8, 2002 09:53 AM
