Relay chattering under driver side dash
Old Sep 14, 2012 | 02:06 PM
damonlan's Avatar
damonlan
All systems are working normally, accept my overhead display which is stuck on 12.6mpg, and my battery and alternator voltage check out fine.
So what is causing a relay to be chattering under the dash. Any ideas which one it might be? If not, any advise on how to tell which one it would be so I can try to replace?
2003 F-350, 7.3L PSD, DRW, lariat
Thanks
Old Sep 14, 2012 | 02:18 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Low battery voltage is my first suspect. You might try connecting up a meter in the cab and watching the voltage at first key on and also when cranking.
Old Sep 14, 2012 | 03:51 PM
Christof13T's Avatar
Christof13T
Has it been raining where you are at?
These trucks are notorious for water in gem causing crazy issues.
Try pulling the cover off your overhead and see if it has water in it.
Xtof
Old Sep 18, 2012 | 01:48 PM
damonlan's Avatar
damonlan
problem licked
Thanks for the input guys. So "engine-off" battery voltage checked out at arount 12.7 and running at about 14.3. So, while I was installing the Wix 6637 filter, I took the opportunity to clean and tighten all the battery terminals, they were quite dirty and coated with the white/green corrosion, and seemed a little loose. After reconnecting the terminals and all attached wires, I sprayed with Staybright to minimize any future build up. Guess what, no more relay chattering.
Tugly
13
Nov 30, 2015 08:42 AM
nautikalhorizon
Aug 2, 2013 09:24 AM
bulldogchief
1983 - 2012 Ranger & B-Series
Oct 28, 2012 11:11 AM
BradyCouchman
Nov 22, 2009 11:28 PM
tom2131968
1978 - 1996 Big Bronco
25
Oct 27, 2006 09:28 AM
