1965 300 CID carb trouble
I have a 1965 F150 with a 300 cid straight six, manual 3 on the tree. I think I may have a carburetor problem, it is original and it looks like the previous owner fiddled with it (darn). Timing looks good, vacuum is near zero at idle but erratic when I hand manipulate the throttle. It starts and idles fine, but when I get it on the road it keeps stalling. I have to restart it several times, usually just after I take my foot off the gas.
Any troubleshooting suggestions?
Paul
Paul
Exactly, the book says 17-19". I took the line off near the carb where it comes out for vacuum advance.
I was thinking about the fuel filter. The original one that attaches to the carb is missing and the previous enthusiast goobered it up with JBweld (no filter) and a fitting that, of course, doesn't fit the NAPA replacement.
Thanks, when I first started on it the carb was squirting gas. I gently tightened the already mangled float housing screws to stop it. I'll go back and check the carb to manifold nuts. I'll look to see if there are any other vac leaks. I replaced the vac tubing to the vacuum advance since it was a bit cracked.
It looks like the only fuel filter is the one on top of the fuel pump. I'll pull it and visit the parts store. Not sure what number it is.
Paul
Paul
if you're new to the '65, you may want to read this:
Classic Inlines Ford Six Load-O-Matic Distributor & Spark Control Valve
the stock configuration would have been a load-o-matic carb & distributor. lots of people don't aren't familiar enough to know that these pieces are a matched set- you can't change one without changing the other. make sure your setup isn't mis-matched.
1986F150six
08-03-2011 01:32 PM
Superred2
12-15-2010 11:43 AM
ohiofossil
07-04-2006 08:58 AM
