Gauges pegging.
Gauges pegging.
Okay, guys. After having searched the forums here for a bit I couldn't seem to find an answer to this so I thought I'd post.
Recently I experienced some gauge problems. I'm driving along and my gauges climb to the top. They stay maxed for a bit but then release and go back to normal. This is the second time since I've owned the truck that this has happened to me. Here's what happened today.
I've been experiencing some engine cooling issues lately so I have been keeping an eye on my Temp gauge. At work I "topped off" my radiator. I've been doing some repairs on my coolant system and check my fluid levels often. By "topping off" I meant that I filled my radiator but left about an inch of space between the bottom of the neck of the radiator filling cap and the top of the coolant. In other words I didn't fill it to the top.
While driving home I saw that my Temp gauge was maxed out. After crapping my pants I pulled off the road to visually check my engine. There were some coolant drips but I chalked those up to clamps not being tightened enough. After having previously driven the truck on the freeway and not noticing any drips under the truck after having parked it, to have dripped as it did was strange. During my visual check I touched the upper hose. It was hot but not as hot as I would have expected with a topped out gauge. I could even briefly touch the radiator without burning my fingers. I tightened the "loose" clamps and started the truck again. The Temp gauge stayed in the middle of the normal range.
Thoroughly confused I pull back onto the road only to have my Temp gauge top out again at the next stoplight. As I drive the engine seems to cool down (gauge-wise) but heats up again at the next stoplight. As I was driving I happened to glance at my other gauges and noticed my Oil pressure gauge was showing my pressure was high. My Alternator gauge was leaning well into "C" territory and I had much more fuel than when I started my trip.
I'm not quite sure what to think. After seeing all this, I was looking at the gauge cluster again and notice a "release". All my gauges returned to where I would expect them to be, even my Temp gauge. I watched them drop back to normal.
Does anyone have any friggin' idea of what this is all about? Thanks in advance.
Correct, on the backside of the instrument cluster.
I believe it's about a $50 part so test it with a VM before buying new, it should pulse 5v every second or so if working properly. <!-- / message -->
<!-- controls -->
I'd like to get a water temp gauge that flashes when the temp gets critical.
three on the tree
01-15-2019 04:08 PM
hman108
11-06-2017 05:00 AM
pistol pete
12-23-2004 09:58 AM
