keeping the door closed without slamming it (1953)
i have to slam the passenger side door on my 53 and it still opens.
I found a newer door latch part that goes in the door jam. the star shaped part of the door latch mechanism on the door tends to wear into that latch making the door not shut tight, check that part for wear. or maybe it just needs to be adjusted? good luck.
oh and if you happen to have a service manual for that truck it should detail those fixes. I have yet to get the service manual for mine
Check the hinges for wear also. They are a great design but if the door sags when you open it look for movement at the hinge pins when you lift the door.
The next most likely is the door adjustment at the hinges. My hinges were tack welded in place perhaps at the St. Paul plant where it was built. If yours are not welded you may have a hinge plate that shifted or perhaps your body geometry changed? Suggest that you check your cab mounts.
jstihl
05-20-2018 09:46 PM
