Trans problems on a 2002
Looking for ideas on a truck my father recently bought. 2002 F250 7.3L Auto CCSB, 189K miles. Hutch/Harpoon/Pre-pump Filter. Full and clean trans oil, no leaks anywhere (engine or trans).
When starting out (cold), the truck runs like a turtle. The engine RPM runs to 1500, but the ground speed increase is extremely slow. Actually acts like you are creeping.
When starting out (engine warmed / hot), the trans pushes a little better, but essentially the same acceleration.
The truck will eventually get to speed, it just takes a LOOOONG time. My father thinks it is stuck is OD, but the OD off light will not go out.
Is this a controller issue or could this be more involved?
I'm flying blind with the trans here, guys, so any thoughts or tests would help.
