Is the GWVR the actual weight
Good question... here's the definition from Wikipedia:
"The gross vehicle weight rating (also gross vehicle mass, GVWR, GVM) is the maximum operating weight/mass of a vehicle as specified by the manufacturer including the vehicle's chassis, body, engine, engine fluids, fuel, accessories, driver, passengers and cargo but excluding that of any trailers. The term is used for motor vehicles and trains."
GVW (gross vehicle weight) is the maximum weight that a vehicle can weigh when fully loaded. This includes, fuel, oil, coolant, occupants and cargo.
To get how much you can carry in a truck you take the GVW and subtract the empty weight.
Example:
Your truck has a GVW of 6100 lbs and empty it weighs 4400 lbs with oil and a full tank of gas. That means you can carry 1700 lbs of occupants and cargo.
You need to load it so the weight is balanced between the front and rear axles, you don't want to load all the weight on the rear axle, that would make for some light (and scary) steering.
Example:
Highmark18
Fifth Wheel & Gooseneck RV Towing
51
01-16-2022 11:55 AM
96ford4x4turbodiesel
15
04-18-2004 05:49 PM
