Any chance of saving this 1959 F100 4x4 Custom Cab rust bucket
#31
on
get it close, put it in low transfer, front hubs unlocked, fresh battery, DISCONNECT FUEL LINE FROM FUEL PUMP, maybe pull a few plugs if you feel you need to and back it in with the starter. i have done this and it works great when you are not on flat ground and you cant find any help. make sure you disconnect the fuel line from the pump or it will pump the worst smelling crap all over everything when all the lines and carb start to leak. Ask me how i know!!!!!!!!!
and hurry up and get that jem home. i havent been sleeping well knowing this wasnt a no brainer for you! JK............kinda.
#32
But, the truck is registered by its specific VIN, and this same VIN is hidden, stamped on the frame rail. So if swapping Rating Plates, the VIN's will no longer match.
If you have to get the vehicle inspected by the polizei before it can be registered and they discover the VIN's don't match, you may have to prove in court, that you didn't steal the vehicle. Not pleasant!
But, as long as the frame isn't changed, there's no reason to worry about the VIN
#33
#34
The VIN is stamped on the Rating Plate, located either on the glovebox door, or on the A pillar (windshield post), visable when the door is opened.
#36
If I run out of time and have to move this truck without the pink slip and Non op cert I would think it's still worth the trouble of dealing with the DMV after the fact. I'm not sure of the CHP implications of trailering a Non Op vehicle without proof of ownership.
#37
#38
Just the site of this truck on a trailer behind my Excursion should make any red blooded American smile. I am just thinking about it. Tickets for things like moving a unregistered vehicle only punish people who can't afford to pay them.
#39
I did get stopped once by a trooper who did just want to look over my 37 Chev and "is it for sale?"
#40
Ok so today I made a trip over to dig this truck out of the ground and get some better rubber on the rims. Took few pics for your entertainment. Turns out the truck hasn't moved since 1996 or so according to the licence tag. Two tire are still holding air after all this time and the two on the driver side were toast so I got some Maypops on there so I can roll it on the trailer.
#41
#42
No snakes, but I killed at least half a dozen big black widows and one nasty big ol centipede.
By looking at the vin plate can you tell what size motor it had originally or any other info you guys can extrapolate from it. Thanks again for the support.
#43
Thanks, It's just like I remembered it Freakin Awesome!! The two tires on the driver side are smaller than the passenger side so it actually leaning a bit.
1959 Ford Pickup Truck F Series Shop Service Repair Manual Engine Drivetrain | eBay
<TABLE class="li rsittlref" itemtype="http://schema.org/Offer" itemscope="" itemprop="offers" r="1"><TBODY itemtype="http://schema.org/Product" itemscope="" itemprop="itemOffered"><TR itemtype="http://schema.org/Offer" itemscope="" itemprop="offers"><TD class="pic lt"></TD><TD class=dtl>and a link for an electronic copy:
</TD></TR></TBODY></TABLE>
http://www.ebay.com/itm/FORD-1959-Pi...8042cf&vxp=mtr
#45
Well, I am certainly not an expert, I have been corrected on several occasions but I still continue to try to help folks as best I can. The first thing is, it looks like your truck was originally not a 4X4! The first three letters of you VIN are F10! That is for two wheel drive. F11 was for four by four. The next letter is the engine code which looks to be a "C"! That would indicate a 292 V8. It looks like you have the original in there or something like it. Here's a fun link to look at about this subject. 1959 FORD F100 Information Specifications Resources Pictures There are many experts around here that can give you much more detail than I and they should be along soon. You really should get a Ford shop manual for the truck. They are a great resource. Here's an Ebay link for a paper copy:
