Need 2 speed rear end motor
Old 10-12-2012, 07:00 PM
4 eyes f600's Avatar
4 eyes f600
4 eyes f600 is offline
I have a 1960 F600 with an eaton #13802 2 speed rear end that the motor has stopped working. I have power to both the high and low speed terminals on the motor. I removed the motor and checked it by battery. Nothing happens so I am sure that I have a bad motor. Can these motors be found or is there anyone that rebuilds these motors? Any help would be apprecisted! THANKS!
Old 10-23-2012, 08:54 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Can these motors be found (B2Q-4100-B = 76 available NOS - 27 of the little darlins' listed bottom of page) or is there anyone that rebuilds these motors?
You can rebuild it yourself...
E5HZ-4A098-A (replaced C2TZ-4A098-A) .. Two Speed Rear Axle Shift Repair Kit / 1952/85 all with electric motor / Obsolete
Last MSRP: $151.26 // Dealer net cost: $100.84.
GRIFFEN FORD in Louisburg NC has 1 = 919-496-4169.
DICKERSON MOTOR CO. in York SC has 1 = 803-684-4225.
GREEN SALES CO. in Cincinnati OH has 9 = 800-543-4959.
PARTS INTERNATIONAL in Farmers Branch TX has 18 = 888-727-0418.
C2TZ-4A098-A may be cheaper since it was replaced in 1985 with E5HZ-4A098-A
CARPENTER NOS OBSOLETE PARTS in Concord NC has 2 = 800-476-9653.
DON SANDERSON FORD in Glendale AZ has 3 = 623-842-8643.
GREEN SALES has 9.
Repair kit comes with the switch, but switch also sold by itself.
B2Q-4107-A .. Two Speed Rear Axle Electric Shift Switch / Obsolete
JST AUTOMOTIVE in Lebanon TN has 2 = 615-443-3086.
WESLEY OBSOLETE PARTS in Liberty KY has 3 = 606-787-5293.
CARPENTER has 6.
GREEN SALES has 17.
B2Q-4100-B .. 2 Speed Motor / Obsolete
JST has 2.
GREEN SALES has 4.
WESLEY has 7.
Carpenter has 14.
Old 10-23-2012, 09:44 PM
4 eyes f600
Thank you so much for your response; however, I found a place local that was able to rebuild mine by replacing with a new motor and new terminal block for $90. The Generator Shop in Gastonia, NC did the work. But again thanks for your help!!!
Old 10-23-2012, 09:48 PM
NumberDummy
Sorry, would have responded sooner, but was away for several days, didn't see your thread until a few minutes ago.
But now you have sources (some in NC) in case motor dies again.
Old 10-24-2012, 09:40 PM
4 eyes f600
No problem; thanks again; your time and information was not wasted because I will keep on file. Have a great day!
Old 10-24-2012, 11:31 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,595 Likes on 1,300 Posts
Is that a "new to you" truck, or have you had it a while?
Old 10-25-2012, 06:31 PM
4 eyes f600
I have owned the truck since 7-13-12. It belonged to a neighbor of mine who owned it for about 10 yrs. I had the 2-speed rear end rebuilt recently; everything else is in good shape. Hope to do some body work and paint the old truck someday because I love driving it; just wish it was a dump truck but you can't have everything.
Old 10-25-2012, 11:42 PM
85e150's Avatar
85e150
You 100% on the two speed? You can't just shift them like a trans....
I will dig up the Eaton links if you like.
Old 10-26-2012, 11:43 PM
4 eyes f600
That would be great. Thanks!
Old 10-27-2012, 12:32 AM
85e150's Avatar
85e150
Post 5 here.
https://www.ford-trucks.com/forums/1...-problems.html
Watch the Eaton videos regarding split shifting etc.
Old 10-27-2012, 10:29 PM
4 eyes f600
Thanks for the videos; I have seen them b4 but never hurts to brush up on your shifting technique; I am still trying to get the hang of it, I do better at times than others.
Old 10-28-2012, 12:55 AM
85e150's Avatar
85e150
My dad just used the two speed as a "5th gear". When I split shifted it, I thought he was going to come out of the seat.
Just remember, no shifting going down hill. And downshift only under load.
As you can see from that thread I posted, some folks shift them any old way, and I saw a guy shift a '70s Chev C60 that way. You sure could not do that with my dad's '58 F600, so I recommend you take it easy and follow Eaton's instructions, and you will be fine and that two speed will still be working at your estate sale.
Old 10-28-2012, 06:37 PM
4 eyes f600
I agree with you 100%
THANKS again
MAP53
08-01-2015 04:29 PM
Mustangking1
06-11-2015 10:21 PM
The fridg 59
02-08-2015 12:49 PM
hotrodhenson
03-19-2009 04:54 PM
Jeff3298
84
07-15-2008 06:52 AM
Quick Reply: Need 2 speed rear end motor
