86 5.0l EFI ADO
86 5.0l EFI ADO
I pull the engine and reinstalled and everything worked. I check the transmission fluid and it was dirty and brown. I dropped the pan and got a new filter and gasket. Nommeatal in pan and not a lot of stuff. I than drain the torque converter and add clean transmission fluid 6quarts out of the 12 required. Started the card and rand for 5 mins in park, move thru gears spending about 5min in each. No change in fluid level, color or tempeture?
Let truck run for 30 mins. Nor change in fluid? Truvk will move into gear but tuck will not move in any direction.... Any ideas.
The filter can only go,one way and is bolted in. I triple check everything before putting the pan back on. It's only supposed to talk 12 quarts total.
So what's my next step?
ryito1122334455
07-03-2011 05:41 PM
vze2sgxa
1997-2006 Expedition & Navigator
05-29-2009 02:15 PM
bluesky
04-26-2001 08:06 PM
