Double Cardan CV joint rebuild?
Old 09-02-2012, 05:38 PM
deere55's Avatar
deere55
deere55 is offline
So I tore into the front drive shaft to replace U-joints. I was able to wiggle the shaft about a half inch. After taking it apart, I noticed the CV joint ball was wiggling about the same amount.
Has anyone tried one of these rebuild kits?
Buy Neapco Double Cardan CV Ball Seat Repair Kit 7-0081NG at Advance Auto Parts
Or should I spring the extra dough for the whole yoke...
EDIT: That kit is priced at $30, but I could get the whole yoke through rockauto for $48. The only thing is I would have to wait for it..
Old 09-02-2012, 08:01 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
It all depends on what is worn on yours. If the pin is worn you are screwed, that is a welded part of the shaft
Old 09-02-2012, 08:12 PM
deere55's Avatar
deere55
deere55 is offline
It seems to be just the ball. Right now I have the yoke completely out, and am able to wiggle the ball in and out of the socket about 1/4 of an inch.
Just wondering if anyone had any experience with these kits.
There's also a couple other concerns I've come across in this project, if anyone could help shed some light on them:
1. The pinion yoke on my front axle wiggles up in down in the axle a little, not sure if it's supposed to do that, and the seal has pretty much come off the walls and I can see into the differential. (I have a new seal to replace that)
2. Also, when I was removing the U-joints on my front driveshaft, a circular piece (some sort of balancing weight?) about 1 1/2" in diameter fell off the rear end of the shaft.
Old 09-02-2012, 08:25 PM
Diesel_Brad
Sounds like you need a new ball and seal
I used a NAPA kit because the Advance kit was missing something(cant remember what)
That is NOT good. IIRC the D60 pinion yolk nut should be torqued to 240-300ft/lbs. I would see if you can torque it. If you can then replace the seal and retorque it and use locktite to hold it
I wouldnt worry about the weight unless you have a vibration
Old 09-02-2012, 09:12 PM
deere55's Avatar
deere55
deere55 is offline
Actually it seems like the whole thing is moving in the differential, not just like the nut is loose.
Old 09-03-2012, 07:22 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,151 Likes on 910 Posts
You have a serious problem here that needs to be repaired. Way beyond a simple seal change IMHO.
Old 09-03-2012, 07:47 PM
fdude64's Avatar
fdude64
fdude64 is offline
sounds like the pinion bearing is toast
Old 09-03-2012, 10:24 PM
deere55's Avatar
deere55
deere55 is offline
How does a guy go about changing that?
EDIT: Actually, I've been thinking about switching this truck from 4.10 to... something else, 3.73 or 3.55 I guess. Tired of screaming 2300 rpm at 60 mph. Is that a pretty "doable" thing, or am I crazy?
Rudeman
2004 - 2008 F150
17
03-22-2012 01:58 PM
wreckinball
04-26-2010 06:26 PM
Wide Open Throttle
13
12-27-2009 08:24 PM
fairchase
1999 to 2016 Super Duty
12-05-2008 09:23 AM
dieselaholic
01-28-2008 11:37 AM
Quick Reply: Double Cardan CV joint rebuild?
