IAT
IAT
Today it was 106* out with a 30mph headwind. I saw temps that I haven't seen before. My oil was 225*, trans 205* and coolant about 225*. What really surprised me was the IAT, it was 166* under the hood!! I don't know for sure if the scangauge reading for IAT are to be trusted but mine over the last few years seems to be accurate.
Travis, Today I saw 174*, wow. In the morning it read 68* when it was 70* out. If I'm drawing in that hot of air maybe that's ONE of the high EGT's problems I have.
Richard, that might be a good idea. I have left the snorkle on but maybe the ducting would help. Sure can't hurt.
It was 107* today and I was hurting. Saw 227* on the trans and felt it slip a couple of times, here we go again for trans number three. If I can get it back home to AZ in Oct. then its off to get a John Woods.
Richard
Glenn, on the scan gauge what PID are you using? The correct one should be "Air Intake 2". Don't know what "Air Intake 1" does or if it would give you bad readings on higher temps, probably for 99 up ...
Checked mine today and it's close to ambient driving and about 10 degrees above ambient sitting, of course it's cooler up here in Oregon. Also check out the new Interceptor web site as they redesigned it and a bit more user friendly. Also the tech forums are an interesting read ...
Interceptor OBD2 data stream gauge and scan tool by Aeroforce Technology
62stepside
08-19-2003 10:46 AM
