Auto To Manual
Jon, I am sure you have a big reason for wanting to do the swap, but that C6 aint no throw away tranny. They are considered by many to be bullet proof & one of the better auto trannys ever built. I recommend rebuilding your C6 over all the work that it will take to go manual.
You will have the fun experience of the job and shifting your own gears, but a better tranny, not so much.
John
John
I was doing an engine swap, and in the process of putting the new one in, the bell housing was damaged.
True, I have never had any problems with the tranny, except for a few leaky gaskets which I haven't fixed yet, but I figured since I'm gonna have it all apart I would at least see what my options are for the tranny.
I am an absolute newbie, everything I know I have taught myself, found out from the guys that were buying these new, or learned on ford-trucks. So I would like to not have to mess with rebuilding it.
The reason I wanted a manual was mostly just for the heck of it, but I've heard I might get a little bit better mileage with it too.
But I have seen your comments on other stuff and think you've got your head screwed on pretty straight so I'll probably take your advice.
Thanks - Jon
Thanks - Jon
Being a 3 pedal man all the way, I don't see anything wrong with your idea. I agree on the donor tuck idea. Parts you will need are the pedals, the rod and boot that go through the floor, the Z bar and brackets and the clutch adjuster rod and spring. And of course the tranny, bell housing, clutch and drive shaft.
I would hardly consider the swap worthwhile unless there was overdrive involved. About the only one that would be a bolt up is the T85 that was optional in those trucks. It's a 3 speed with overdrive in every gear (almost, first has a lockout you have to bypass). Cool thing on those is that you can wire the solenoid to a switch and have like a splitter making it a six speed. Also you could probably make one of the 3+OD trannys work but they are a little weak for a 390.
Nothing wrong with the C6 if you like an automatic. They do have some parasitic drag and might knock mileage down a little from a good overdrive stick but it would take quite a while to offset the cost with any realized fuel savings.
John
Austy, I just installed an AOD in the 67.... it had a 3 gear on the floor, but after loosin my left leg last year, decided to go auto..... the truck still has the clutch pedal, linkages, ect in it, BUT to go to an auto setup, im gonna need the "auto brake pedal setup" cause the clutch pedal assembly is what holds the brake pedal in place (if I read the diagram rite)....
Not sure what shippin would be, but would be interested in a trade.... if it perks your ears, gimmie a hollor....
GE (Granbury, TX)
GE (Granbury, TX)
Thought about doing a swap to manual myself. I have a '67 F250 with a cruise o matic and it's the first auto I have ever owned. I have to say though that I have gotten used to it. I still regularly reach for the shifter and try to step on the clutch pedal like I did in my old '78 F150, but it's kind of nice having one of my three vehicles that doesn't require intervention to roll to highway speed. After all, there are no cup holders and where would I park my coffee so I could shift? The only issue I have with an auto is I know nothing about it. I want to get it serviced but am afraid I'll be told it's toast because of metal shavings in the pan. I remember the AAMCO ordeal in the '80's as a teen and the hidden cameras catching 'em telling folks they needed work that they really didn't. I just don't know what an auto needs never mind one that's 45 years old. It's working okay as far as I know right now but it's startin to leak fluid....
