Flareside bed floor
Old 08-27-2012, 10:20 PM
KC Ray's Avatar
KC Ray
KC Ray is offline
Flareside bed floor
I can't decide what I want to do with the floor of my bed. Right now I have a couple of cut up sheets of OSB just to have a floor. It's just the bare metal frame under that. What have you guys done that is a cheap way of putting in a bed floor?
Old 08-27-2012, 11:08 PM
GB SISSON's Avatar
GB SISSON
GB SISSON is offline
On a couple of flaresides I've had in the past I have always used rough sawn lumber from local sawmills. I'm a lifetime professional woodworker so the work is second nature. Buying the strips is the hardest part. I have recently built 2 steel flatbeds and I prefer a wood deck so I used 3/4" pressure treated plywood. One is about 5 years old and still looks new. Unfortunately you will need 2 sheets or you will be doing a lot of piecing together at the fenders. If I was doing it for a driver on a budget, that's what I would do. If you have a shop and woodworking tools you can go the traditional route. There are a few companys that make the whole kits, but can get real expensive. Any of these beats what you now have.
Old 08-28-2012, 04:20 AM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
3/16 steel deck plate would be a good option too. Probably about $125 for a 4x8 sheet. You might get a 5' wide sheet.
Old 08-28-2012, 04:56 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Mar-K (mar-K.com) located in OKC reproduces SHORT Flareside pickup beds and all the bed parts including tailgate, wood and steel bed slats, all the mounting hardware.
Wood bed kits also available from Carpenter in pine (original) and oak. Bed slat kit sold separately.
Y'all know, of course...that the wood was painted body color originally.
Old 08-28-2012, 01:58 PM
GB SISSON's Avatar
GB SISSON
Just a little backup for Bill's comment about bedwood being body color. Mine has original wood and although a PO painted it blue, there is plenty of meadow green still showing. I save the varnish for table tops....Everyone says they like pictures so here's a couple.
Old 08-28-2012, 08:06 PM
spurredon's Avatar
spurredon
spurredon is offline
Gary, I still can't believe how great condition that box is!
wprobasco
1999 to 2016 Super Duty
10-23-2015 07:41 PM
BaltoMoJoe
12-15-2014 06:52 PM
ahawes
12-19-2005 08:46 PM
Cracker289
11-27-2004 10:14 AM
46yblock
1947 and Older Ford Trucks
01-18-2004 05:57 PM
Quick Reply: Flareside bed floor
