Here are my trouble codes
634 Manual Lever Position Sensor Voltage Higher Or Lower Than Expected
I'm thinking bad VSS based on 452, or is there something else I should check out? I've looked around about 634, and I'm not really experiencing the symptoms that seem to be associated with that code (going into neutral while you're driving).
Any thoughts?
